Angular Acceleration Conceptual Question
A wheel starting from rest with constant angular acceleration experiences an acceleration vector for a point on the rim that increases in magnitude and becomes more nearly radial over time. This is due to the relationship between tangential acceleration and radial (centripetal) acceleration, where the tangential component increases as the wheel speeds up. The formula At = alphaR indicates that tangential acceleration is directly proportional to angular acceleration and radius. As the wheel accelerates, the radial component becomes more significant, leading to the conclusion that the acceleration vector's direction shifts towards the center. Understanding this concept is crucial for grasping the dynamics of rotating systems.
_buddha
A wheel starts from rest and spins with a constant angular acceleration. As time goes on the accerlation vector for a point on the rim:
a) decreases in magnitude and becomes more nearly tangent to the rim
b) decreases in magnitude and becomes more nearly radial
c) increases in magnitude and becomes more nearly tangent to the rim
d) increasese in magnitude and becomes more nearly radial
e) increases in magnitude but retains the same angle with the tangent to the rim
At = alphaR
the answer is d, but i just don't understand why. Why does an acceleration vector for a point the rim become radial ?
At = alphaR
Hint: The other formula is v^2/R.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
