What is the relationship between speed and radius for a car to avoid skidding?
The relationship between speed and radius for a car to avoid skidding is based on the equation f = mV²/R, where the centripetal force is provided by static friction. When a car's speed is doubled, the velocity squared becomes four times greater, necessitating a radius that is four times larger to prevent skidding. This means that if a car can round a curve of radius R at speed v without skidding, it can only round a curve of radius 4R at speed 2v. The maximum static friction remains constant, which is crucial for maintaining control. Understanding this relationship is key to safe driving on curves.
Jeann25
If a certain car, going with speed v, rounds a level curve with a radius R, it is just on the verge of skidding. If its speed is now doubled, the radius of the tightest curve on the same road that it can round without skidding is:
Answer is 4R.. but I don't understand why?
I know the equation is f = mV²/R
in the equation, the velocity is squared.
if the velocity becomes 2V, when you square it, it becomes 4V^2. to keep the car from skidding, the radius now has to change to 4r
Also, it is important to understand that the static friction, the source of the net centripetal force, is at its maximum value, and does not change.
I get it now. Thank you! :smile:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
