Angular momentum: disk with point mass on the edge
The discussion centers on calculating the instantaneous angular momentum of a disk with an additional point mass on its edge, which is both rotating and translating. The total angular momentum of the system can be determined by summing the angular momentum of the disk and the point mass. However, the moments of inertia must be adjusted to account for the shift in the center of mass caused by the point mass. It is clarified that the moment of inertia of the disk changes depending on the axis of rotation, and the contribution from the point mass must be included in the calculations. The conversation emphasizes the importance of understanding how the addition of the point mass affects the overall dynamics of the system.
willywilly
Hi all,
I'm treating a problem concerning a disk containing an additional point mass on the edge. The disk is moving (rotating and translating) relative to another fixed point, meanwhile it's spinning about its axes of symmetry.
I'd like to determine the instantaneous angular momentum about the disk center and the resulting instantaneous moment the system (point mass+disk) exerts on the disk center.
Is the total angular momentum equal to the angular momentum of the point mass + the angular momentum of the disk?
Is it allowed to consider the moments of inertia about the disk center unchanged when an additional point mass is added, neglecting the latter?
Thanks in advance.
Regards,
WillyWilly
you can assume the conservation of angular momentum
Not clear where the point of rotation is - is it fixed at the centre of the disk?
In other words a shift in centre of gravity when the point mass is added on the disk
The rotation is about the center of gravity of the disk, called G, containing no point mass.
Total angular momentum is indeed a simple sum of angular momenta of the constituents, as are the moments of inertia, but it is not that simple in your case because the moment of inertia of the disk (without considering the point mass) is different about different axes, and the presence of the point mass fixed to the disk has shiften the centre of mass outwards from the centre.edit- oh I misread, if the disk is still spinning about its centre, then the total moment of inertial is that of the disk plus the mr^2 from the point.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
