Angular Momentum of a billiard ball
To achieve rolling without slipping for a billiard ball, the cue must strike the ball at a height of 2r/5 above its center. This ensures that the tangential velocity is twice that of the center of mass velocity, satisfying the condition for rolling without slipping. The discussion emphasizes the importance of torque and force relationships, using Newton's laws to derive the necessary height for the strike. The calculations confirm that the distance above the center where the cue should hit the ball is indeed 2/5 of the radius. This result is critical for understanding the dynamics of billiard ball motion.
Destrio
To get a billiard ball to roll without sliding from the start, the cue must hit the ball not at the center (that is, a height above the table equal to the ball's radius, r) but at exactly at a height of 2r/5 above the centre. Prove the result.
For a ball to roll without slipping, it must have tangential velocity twice that of its velocity of the centre of mass.
so tangengial speed = ωr
at the point where the wheel contact the surface must be at rest
vcm - ωr = 0
vcm = ωr
L=Iω = Ip/mr
p = Lmr/I
so for conversation of momentum
mvcmi = mvcmf + Lmr/I
Δvcm = Lr/I
I for a sphere = (2/5)mr^2
where r is where the ball needs to hit
Δvcm = L/(2/5)mr
(2/5)mΔvcm/L = r
(2/5)Δp/L = r
(2/5)r = r
these last few steps don't seem right?
are they? am i even correct up to there?
thanks
Maybe I'm just braindead tonight, but I'm having a bit of trouble following your reasoning. Think in terms of forces. The cue applies a force at some distance above the center. That force creates an acceleration of the center of mass and an angular acceleration about the center of mass. Set the condition for zero acceleration of the contact point (same as rolling without slipping) and solve for that distance.
It's perfectly OK to think in terms of an impulse that produces a velocity of the center of mass as well as a angular velocity. Perhaps that's closer to how you are thinking. (But when I see "conservation of momentum", I get confused. You're hitting the ball!)
And don't use the same letter (r) to stand for the radius of the sphere and the position of the strike.
F = ma
will this force be equal to the torque from the force?
F = ma = T = Iɑ
ma = Iɑ
ma = ɑ(2/5)mr^2
a = ɑ(2/5)r^2
rolling without slipping so:
vcm = ωr
vcm/t = ɑr
vcm/rt = ɑ
and
a = vcm/t
a = ɑ(2/5)r^2
vcm/t = (vcm/rt)(2/5)r^2
r = 5/2 = 2.5
is this the answer I am supposed to get?
thanks
Destrio said:
F = ma
F = ma = T = Iɑ
ma = Iɑ
Yikes. Don't set torque = force!
You have two equations from Newton's 2nd law:
F = m a
\tau = I \alpha
Let the strike be placed at a distance "d" above the center. Rewrite the torque equation:
F d = I \alpha = 2/5 m r^2 \alpha
Combine those two equations (with the condition of rolling without slipping) to solve for d.
F = ma
T = Iɑ
Fd = Iɑ = a(2/5)mr^2
vcm = ωr
vcm/t = ɑr
vcm/rt = ɑ
and
a = vcm/t
mad = ɑ(2/5)mr^2
ad = ɑ(2/5)r^2
dvcm/t = (vcm/rt)(2/5)r^2
d = (2/5)r
there we go!
thanks
Good. Here's how I would do it:
Starting with Newton's law for translation:
F = m a
And rotation:
F d = I \alpha = 2/5 m r^2 \alpha = 2/5 m r^2 (a/r) = 2/5 m r a
Multiply the first by d and set equal to the second:
m a d = 2/5 m r a
d = 2/5r
