Angular Momentum of a sanding disk
The discussion revolves around calculating the angular momentum and angular speed of a sanding disk attached to an electric drill. The rotational inertia of the disk is given as 1.22x10^-3 kgm^2, and the motor delivers a torque of 15.8 Nm. Participants clarify that the time of 33.0 ms can be used to find angular acceleration and subsequently angular momentum. The formula L = Iω is applied, leading to the conclusion that angular velocity can be derived from torque and time. The final conversion from radians per second to revolutions per minute is also addressed.
Destrio
A sanding disk with rotational inertia 1.22x10^-3 kgm^2 is attached to an electric drill whose motor delivers a torque of 15.8 Nm
a) find angular momentum
b) find angular speed of the disk 33.0ms after the motor is turned on.
L = Iω
τ = Iα
we can find angular acceleration with what we are given α = τ/I
but I'm completely stumped on how to find L without having time.
any hints?
thanks
Here's a hint: You are given the time! :smile:
lol man I stared at that over and over again and thought, "I must be misreading this...wheres the trick?"
But seriously, yes you are given the time. its "33.0ms" part
Haha, thanks
I realized from that that I can use the time to solve the first part of my problem.
L = Iω
L =τω/α
ω = αt
L =τt
that works
τt = Iω
ω = τt/I
which gives me 427m/s
but i need the answer in rev/min
im okay with seconds to minutes, but how do i convert meters to revolutions?
2pi?
If you can find its angular acceleration, then ( just like linear kinematics... ) its angular velocity is equal to its angular acceleration multiplied by the duration of the acceleration.
Destrio said:
τt = Iω
ω = τt/I
The units for ω are radians/sec, not m/s. One revolution equals 2 \pi radians.
woo i got it!
thanks
