What Angular Speed Must Earth Rotate for Equatorial Weight to Drop by 25%?
To determine the angular speed required for a person at the equator to weigh 75% of their current weight, the centrifugal force must counteract part of the gravitational force. The equations involved include the relationship between angular speed (w), radius (r), and gravitational acceleration (g). The user attempts to calculate the new weight using the equation wt = 0.75 x m x 9.8 but struggles to connect weight and angular speed. The key equation to use is the centrifugal force equation, F = m r w^2, which relates angular speed to the desired reduction in weight. Further assistance is sought to clarify the connection between these variables.
9giddjl
Angular Speed of Earth when...
Determine the angular speed with which the Earth would have to rotate on its axis so that a person on the equator would weigh 75% of their present weight (Radius of the Earth is 6400 km)
wf=2pi/T
wt= mg
v=wr
First I did wt=0.75 x m x 9.8, the problem is i can't find any equation that could incorporate weight and angular speed. Can somebody please give me some hints? Any help would be appreciated:) Thankyou very much
Centrifugal force = m r w^2 where w is the angular speed in radians/sec.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
