Another Absolute Maximum Question
  • Thread starter Thread starter jegues
    Absolute Maximum
jegues
Find the maximum value of the function f(x, y) = x^{2} - y^{2} + x considering only points inside and on the boundary of the region bounded by the curve,
x = \sqrt{1-y^{2}}, x=0
See figure attached for my attempt.
I drew a quick sketch of the region given and I've found it to be a circle with a vertical line passing through its center. That being said, I didn't know what "half" of the circle was my enclosed region. Is it the left half or the right half? How do you distinguish this?
I continued working while only considering the "right half" as my region.
I found the critical points inside my region and continued to look for critical points along the edges of my region.
I labeled these accordingly, C1 and C2.
I still haven't obtained the correct answer of 2, so I'm not entirely sure what I've done wrong.
Could someone help me out?
hi jegues! :smile:
jegues said:
… I didn't know what "half" of the circle was my enclosed region. Is it the left half or the right half?
you haven't read the question carefully enough :redface:
√ means the positive square root (or zero), so it has to be the right-hand half! :wink:
you were ok up to h' = 4x + 1 …
since that's always positive (in the region), h reaches a maximum at the maximum boundary of x :smile:
tiny-tim said:
hi jegues! :smile:
I'm not entirely sure what you mean by maximum boundary of x.
Do you mean the largest value of x I can obtain in the region provided? That would simply be x=1.
Therefore h(1) = 2, which would correspond to my absolute max, correct?
Yup! :biggrin:
Why is this different then the standard procedure when checking for critical points along the edge of a region?
I'm used to having to take a derivative and equate it to 0 in order to figure out my point of interest.
What makes this different?
hi jegues! :smile:
(just got up :zzz: …)
It isn't different …
you equate the derivative to zero along the semi-circle boundary …
(if there's a solution, then of course that's your solution, but if there isn't a zero, then …)
with no zero, the solution must be at the boundary of the semi-circle boundary …
looking at it, you'd say the boundary is the two points on the y-axis, but that's wrong because the derivative was wrt x, and x goes from 0 to 1, so the boundary is at x = 0 or 1 :wink:
(and since the derivative wrt x is positive, the maximum must be at x = 1)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
