What Are the Possible Values of Ly After Measuring L^2 as 6(h bar)^2?
J man
Suppose L^2 is measured for a system and the value 6(h bar)^2 is obtained. If Ly is measured immediately after, what possible values can result?
(L^2)psi= (h bar)^2*l(l+1)psi
(Ly)psi= m(h bar)
to begin, I know L^2 and Ly are compatible (I think that matters in this case)
Now, I know when L^2 is applied to a system, the eigenvalue is in the form of:
(h bar)^2*l(l+1)
so, since I know my measured value was 6(h bar)^2, I then solved for l and got 2.
this means that my m values range from -2 through 2.
then I assumed that by operating the Ly operator and observing the system, the possible values take on the values of m(h bar) where m ranges from -2 to 2. Is this correct?
Yes that is perfectly correct. When you say 'compatible' you mean the L^2 and Ly operators commute.
Might be worth pointing out that m ranges from -2 to 2 in integer steps. Thus possible values of m are -2 -1 0 1 2. There are always 2l+1 possible values of m.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
