Another convergent and divergent
tnutty
Determine whether the series is convergent or divergent.
\sum n5 / (n6 + 1)
hi tnutty - any ideas?
maybe a comparison test...
Yes I was thinking of the comparison test, but that's next chapter. in this chpt, its all about integral test. i am not sure how to solve this with integral test, but can you check out the comparison test that follows ?
Comparison test ;
n^5 / (n^6+1) <= n^5 / n^6 = 1/n and from definition we know that 1/(n^p)
converges if n > 1 and diverges if n< 1. So in this case it diverges since n = 1.
Any ideas solving this by integral test?
Comparison test ;
No, you can't conclude from this comparison that the series diverges. For the comparison test to show that a series diverges, the terms have to be larger than those of a divergent series. Here you show that they are smaller than those of \sum 1/n.
rwisz said:
The comparison test does show divergence that's right.
Sorry to burst your bubble, but no it does not. Take a look at the comparison test and what it says about divergent series and what it says about convergent series. They are different.
rwisz said:
For the integral test however, since the numerator contains n^5 and the derivative of the denominator is 6n^5 then you should be able to tell that u-substitution will work like a charm here...
Hint: du/u = ln u.
And for the setup of the improper integral, try looking at the previous thread where I helped you, at the bottom of my last post.
as Mark mentioned out the comparison test points out that if
b_n &gt; a_n for all n>N then if an diverges so does bn
so your pevious example doesn't work...
but to get this condition you could notice
\frac{n^5}{n^6 + 1} &gt; \frac{1}{2n} which is true \forall n &gt;1
or
\frac{n^5}{n^6 + 1} &gt; \frac{n^5}{n^6 + n^5} = \frac{1}{n+1} which is true \forall n &gt;1 and cleary diverges...
clearly
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
