tickle_monste
- 67
- 1
If we can shoot a photon outward, at velocity c, why is it that the body that shot it outward is not traveling away from the photon with velocity c?
jnorman said:individual photon has no reference frame, as it has no location.
Photons do have a location in any given inertial frame, but they don't have an inertial rest frame of their own. In any given inertial frame, if you take the photon's position coordinate at one time coordinate and then look at the same photon's position coordinate at a different time coordinate, you will have (change in position)/(change in time) = c (as long as it was traveling in a vacuum the whole time).tickle_monste said:So how is it that we say that it travels with any speed at all, and if it's traveling away from its source of emission, why is that source not traveling away from it with velocity c?
JesseM said:Photons do have a location in any given inertial frame, but they don't have an inertial rest frame of their own. In any given inertial frame, if you take the photon's position coordinate at one time coordinate and then look at the same photon's position coordinate at a different time coordinate, you will have (change in position)/(change in time) = c (as long as it was traveling in a vacuum the whole time).
Bob S said:If a nuclear isomer emits a gamma ray and recoils, the momentum of the emitted photon and of the recoil nucleus are equal. Because the nuclear mass is so high, the recoil is in most cases negligible.
In a transparent medium the light velocity is smaller than "c" so there is a co-moving reference frame where the light is at rest and the emitter moves at v<c.jnorman said:individual photon has no reference frame, as it has no location.
How about the annihilation of the positron with an electron at rest. After the positron has annilated with the emission of one 511 KeV photon traveling away at the velocit of light, all that is left is another 511 KeV photon traveling in the opposite direction, also at the velocity of light. This should all be covered in the Lorenttz transformation. Seetickle_monste said:Well, I wasn't assuming there would be recoil. If there were, wouldn't that just put the velocity of the source at a value even greater than c from the photon's reference frame (remember you have been endowed with magical wizard eyes for the purposes of this thought experiment).
I don't understand the distinction, all statements about what would happen in an inertial coordinate system are equivalent to physical statement about which events would happen next to which ruler-markings, and what readings the clocks at those ruler-markings are showing when the events happen in their vicinity, on a physical network of inertial rulers and clocks constructed according to Einstein's procedure for defining inertial coordinate systems. If a photon was next to the 10-light-second mark on a ruler when the clock there read 30 seconds, then if the same photon was later next to the 20-light-second mark on the same ruler, it would be true that the clock at that mark read 40 seconds as the photon was passing it. Are these not statements about physical "reality"? Of course you are free to construct a non-inertial coordinate system in which a photon is moving at some other speed besides c, SR does not forbid this, it just says that the equations for the laws of physics will look different when you express them in this coordinate system then they do in inertial coordinate systems (where they will look the same regardless of which inertial coordinate system you choose).tickle_monste said:This is all very much the domain of special relativity, which is nothing more than a matter of observation. Basically, if you're moving in some manner: accelerating, uniform, w/e, photons will catch up to you differently, and what you observe will differ between different frames of reference. This is all that the Lorentz transformations describe, so when you try to consider a body that photons can't catch up to, i.e. another photon, it's no wonder the theory breaks down, and actually speaks to it's accuracy (incomplete, though it may be). But that's just it, special relativity describes only what is observed, not what is reality.
You're confused, the issue has nothing to do with photons not being able to catch each other--why would it? You are free to construct a coordinate system where a photon is at rest, it just won't be an inertial one, so the equations of SR that work in inertial frames (the time dilation equation) wouldn't apply here. And in fact, you could construct an infinite number of different coordinate systems where a photon was at rest, which would disagree about things like the times and distances between various events (unlike in the case with inertial frames, where there is a single answer to these types of questions if you want to use a given object's inertial rest frame); there's no physical basis to treat any of these coordinate systems as better representing a photon's "perspective" then any other, because the times and distances are not based on actual rulers and clocks which are at rest relative to the photon, they're just chosen arbitrarily (you can't actually have rulers and clocks moving at the speed of light, and even if you consider the limit as they approach the speed of light, the clocks would approach being frozen and the rulers would approach being shrunk to zero length, so these limiting cases don't make a sensible basis for constructing a coordinate system).tickle_monste said:It is for different reasons from general relativity that a particle with mass cannot be accelerated to the c, but that's always the first reason attempts to imagine a photons reference frame are shot down. But now I'm going to just start out assuming that particle is massless, just like the photon who's reference frame I'm trying to understand, so I have absolutely no problem sending this particle right alongside the photon. Now, the second reason all attempts are shot down is because of the notion, derived from special relativity, that the photon should have no reference frame. So, again, this is ONLY, (only? yes, only) because photons can't catch up to one another. Did I say that that's the ONLY reason for the breakdown of the theory at the speed of light? Cause if I didn't: that's the ONLY reason (in special relativity).
Inertial coordinate systems in SR are not usually imagined as being constructed based on what any observer sees using light signals; rather, they are imagined as being constructed based on local readings on a network of inertial rulers and clocks which fill space (so every event happens right next to some ruler-marking and clock-reading in the network) and which are at rest relative to the observer. The only place light plays a role is in defining what it means for clocks at different locations to be "synchronized" in a given frame (the idea is that if you set off a flash at the midpoint of two inertial clocks, and both clocks show the same time at the moment the light from the flash reaches them, then the clocks are defined to be synchronized in their own rest frame, although other frames will say they are out-of-sync due to the relativity of simultaneity). But even this is not strictly necessary, an equivalent synchronization procedure is to synchronize two clocks when they are right next to each other (and at the midpoint of the locations you want to move them to), then move them apart very slowly at equal and opposite velocities in the frame you want to use them in.tickle_monste said:What I'm getting at is that it's not, in any way, nonsensical to attach a coordinate frame to a photon. The only thing that's nonsensical is to try to attach a coordinate frame that is constructed by what the photon 'observes' via the intake of other photons; the whole thing is just undefined.
JesseM said:You're confused, the issue has nothing to do with photons not being able to catch each other--why would it?
They don't have to adjust for the speed of light if they define coordinates of events using local measurements on a ruler/clock network of the type I'm talking about--when the light from the strike reaches them, they can just look at the time on the clock that the lightning struck right next to at the moment it struck (or you can have different observers in the same frame sitting next to different clocks in the network, and any time one one observer sees an event happen right next to him and his clock, he can send a telegram to all the other observers in this frame telling the time he saw--obviously the speed of the telegram is irrelevant here). And as I said, the different clocks in a given observer's network can be synchronized by the method of synchronizing them at a common location and slowly transporting them to their final locations in the network, rather than by using light signals.tickle_monste said:For the most part, we're saying the same thing in different languages, but it does have something to do with photons not being able to catch each other. Enter lightning bolt:
Lightning strikes at time t=0 at location x=0. A person is standing at location x=1. When will they say the lightning bolt occurs, before they've adjusted for the speed of light?
At a theoretical level this can be derived from the two postulates of relativity, which say that 1) if different inertial observers use local measurements on these types of physical networks to define the coordinates of events, then when they write down the equations for the fundamental laws of physics in terms of their own coordinate system, they will all get the same equations; and 2) that if different inertial observers use local measurements on their own networks to measure the speed of a light beam, they will all find that it has a coordinate velocity of c. Logically you can show that the only way for these two postulates to both be satisfied is if the coordinates of different inertial observers are related by the Lorentz transform, from which you can derive length contraction and time dilation. And if you actually had a bunch of such networks moving at relativistic speeds relative to one another, you could use them to measure length contraction and time dilation. For example, if Bob has a ruler that he says in 20 light-seconds long, and he's moving at 0.6c relative to Alice, then Alice might use her own network of rulers and clocks to note that the back end was passing right next to the 30 light-second mark on her own ruler when the clock there read 200 seconds, and the front end was passing right ext to the 46 light-second mark on her own ruler when the clock there also read 200 seconds, so from these local measurements which she judges to be simultaneous, she can say that Bob's ruler is only 46-30=16 light-seconds long in her frame. And if Bob has a clock that reads 100 seconds at the moment it is passing next to a clock of Alice's that also reads 100 seconds, and later when the same clock of Bob's reads 108 seconds it is passing next to a different clock in Alice's network that reads 110 seconds, then Alice judges uses these local measurements to judge that Bob's clock was running slow by a factor of 0.8 in her frame.tickle_monste said:You bring up clocks and measuring rods, but how do you derive the phenomena of length contraction and time dilation?
