Another simple vector question
  • Thread starter Thread starter -EquinoX-
    Vector
-EquinoX-
Find a unit vector from the point P = (1, 2) and toward the point Q = (4, 6).
The answer at the back of the book says 3/5i + 4/5j, shouldn't it just be 3i + 4j?
A unit vector has length 1.
so what do you mean? If I am asked to find another vector that has the same direction with length 10, how do I do that? if I changed the question to (3,6) instead of (4,6) what would be the answer then
-EquinoX- said:
so what do you mean? ... if I changed the question to (3,6) instead of (4,6) what would be the answer then
Multiplying a vector by a nonzero scalar does not change its direction. If the length of a nonzero vector v is a, then (1/a)v has length 1.
The following is then an exercise for you.
ok so if that's so then finding another vector that has the same direction as 3/5i + 4/5j, will be something like
1/10 (3/5i + 4/5j) am I right?
the answer at the back of the book is 6i + 8j, I don't where that came from...
Come on, Equi, what is the length of that vector?
You have \textstyle\mathbf{v} = (\frac{3}{5}, \frac{4}{5}), which has length
.\; \; \; \; \; \textstyle ||\mathbf{v}|| = \left\|\frac{1}{5}(3, 4)\right\| = \frac{1}{5}||(3, 4)|| = \frac{1}{5}\sqrt{3^2+4^2} = \frac{1}{5}5 = 1.
Hence \textstyle 10\mathbf{v} = 10(\frac{3}{5}, \frac{4}{5}) = (6,8) has length 10 since
.\; \; \; \; \; ||10\mathbf{v}|| = 10||\mathbf{v}|| = 10.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
