Answer: Calculating Induced Current in NMR
The discussion revolves around calculating the induced current in a coil due to a time-varying magnetization in the context of Nuclear Magnetic Resonance (NMR) devices. Participants explore the relationship between magnetization and magnetic field, the application of Faraday's Law, and the implications of different types of currents in magnetized materials.
  • One participant questions how to derive the magnetic field from the given magnetization, suggesting the use of Faraday's Law to find induced current.
  • Another participant provides a relation for the magnetic field in terms of magnetization and magnetic susceptibility, but expresses uncertainty about the validity of this relation.
  • Some participants discuss the concept of induced bound currents and differentiate between induced currents and material currents, emphasizing that a constant magnetization does not induce a physical current.
  • There is a debate about the conditions under which the H-field is zero, with one participant invoking Maxwell's equations to support their reasoning.
  • Concerns are raised about the units of magnetic field and magnetization, with participants questioning the consistency of the derived formulas.
  • One participant notes that in nonlinear media, the relationship between magnetization and magnetic field requires empirical data, which complicates the analysis.
Participants express differing views on the relationships between magnetization, magnetic field, and induced current. There is no consensus on the validity of certain equations or the implications of constant magnetization, indicating an unresolved discussion.
Limitations include the dependence on specific definitions of magnetic susceptibility and the assumptions regarding linear versus nonlinear media. The discussion also highlights the complexity of deriving induced current from magnetization without clear empirical data.
This discussion may be of interest to those studying electromagnetism, particularly in the context of NMR applications, as well as individuals exploring the theoretical underpinnings of magnetization and induced currents in various materials.
simorgh
Hi,
Question:
we have a magnetization [itex]M_x[/itex] that varying as [itex]M_x(t)=M_x e^{-t}[/itex].Threre is a coil on the x axe. The magnetization will induce a current in the coil. How can get value of this current.
This situation happen in NMR device.
I try to caculate magnetic flux and then voltage ([itex]v=-N \frac {d \Phi} {dt}[/itex]) to find induced current. But to calculate magnetic flux we need to have magnetic field (B). How can get magnetic field from magnetization?
thanks all to help me.
If the body has an infinite dimension along x-axis but finite dimension along the other two axis , then we have the following relation:
[itex]\vec{B}=\mu_{0}(\vec{M}+\vec{H})=\mu_{0}(\vec{M} +\frac{\vec{M} }{\chi})=\mu_{0}(\vec{M}+\frac{1}{\mu_{r}-1}\vec{M})=\frac{\mu_{0}\mu_{r}}{\mu_{r}-1}\vec{M}[/itex]
I've personally never heard of this relation, but another method (I think) might help cast some light on the situation is through the direct calculation of the induced bound currents:
Jb = [itex]\nabla[/itex] χ M
and
Kb = M χ [itex]\hat{n}[/itex]
where Jb is the induced volume current density (I/A), and Kb is the induced surface current density (I/L). From these, you can directly determine the total induced current.
Hope this helped. :3
P.S., Hassan, do you know what that relation is called? I thought the H field would be 0 in this case, since there is no free current and the divH = 0? I'm rather interested.
and
In my opinion, the above relations don't give the induced current. They give the equivalent surface and volume current densities which are sometimes called material current. They are totally different from the induced current which depends on rate of change and the conductivity. For example when M is time-invariant, we don't have an induced current while your equation could give non-zero currents.
About the relation, it comes from the definitions of [itex]\vec{M}[/itex] , [itex]\vec{H}[/itex] and [itex]\mu_{r}[/itex]:
Maxwell equation for [itex]\vec{B}[/itex] is
[itex]\frac{1}{\mu_{0} }\nabla \times\vec{B}=J=(J_{f}+\nabla \times \vec{M})[/itex]
or
[itex]\nabla \times(\frac{\vec{B}}{\mu_{0}}-\vec{M})=J_{f}[/itex]
then [itex]\vec{H}[/itex] is defined as:
[itex]\vec{H}=\frac{\vec{B}}{\mu_{0}}-\vec{M}[/itex] or equivalently [itex]\vec{B}=\mu_{0}(\vec{M}+\vec{H})[/itex]
so that
[itex]\nabla \times \vec{H}=J_{f}[/itex]
Then we have the experimental relation between an applied field and induced magnetization:
[itex]\vec{M}=\chi \vec{H_{app}}[/itex]
Note that [itex]\vec{H}[/itex] in Maxwell equation is the sum of the applied field and the field rising from the magnetization itself, called demagnetizing field. Under the condition I mentioned, the demagnetizing field become zero, and you get the desired relation. Remember that by definition [itex]\mu_{r}=\chi +1[/itex].
Added: We have M because we have H. Only in a permanent magnet we have M without an applied field.
Ahh, I see.
Though, I'm still having some trouble understanding why the H-field doesn't equal 0 in this case.
From Maxwell's equation, we can invoke Stoke's Theorem to obtain the following relation:
[itex]\int[/itex]H [itex]\bullet[/itex] dl = I(free)
Moreover, Hemholtz' theorem guarantees a viable solution from the curl alone, since div(H) = 0.
From this, shouldn't we deduce that H=0 everywhere, as there is no free current?
Also, you mentioned that a constant Magnetization would not induce a physical current, as is the case here. However, isn't the definition of Magnetization the uniform flow of electric charge, in order to produce a Magnetic field? Magnetization results from the uniform orientation of each magnetic "dipole" (i.e., atom) to produce a net Magnetization-- but isn't this concomitant with forcing the charges to move in a net direction?
I understand that a changing magnetic flux will produce an additional emf (Faraday's Law), but shouldn't any Magnetized object should exhibit some sort of current?
Thanks. :3
Also, I hope I'm not monopolizing this thread with my questions. Just a bit interested. :)
Edit: Also, the experimental relation between M and H only applies to linear media with particular magnetic susceptibility. How would we invoke these equations to solve this problem if they made no mention of linear media and, therefore, magnetic susceptibility? Or perhaps that was left out of the description. :p
1. In a magnetized media [itex]\nabla . H=-\nabla . M[/itex] because
[itex]\nabla . B=\mu_{0}\nabla .(M+H)=0[/itex]
2. About the equivalent current, I hope one of the science advisers of the forum, known as timy_tim, appear and explain it in detail. But one thing I know is that that current is zero in nonmagnetic material. For example in a coil made of copper, you have no M, so you have no equivalent current density. Also that current is not due to drift of free electron, so it can't do work for us. For example a permanent magnet has such an equivalent current but of course we can't turn on a light with it!
Edit: For a nonlinear media, we need to know the B-H curve or M-H curve or the material which is again experimental. This is in classical electromagnetic. In micromagnetics , the relation between M and H is derived more theoretically, and no [itex]\mu_{r}[/itex] or [itex]\chi_{m}[/itex] is required.
Leona74 said:
http://www.infoocean.info/avatar2.jpg I've personally never heard of this relation
Perhaps because we rarely deal with M.
simorgh said:
Hi,
Question:
Use Hassan's formula to calculate the induced voltage (not current) using your expression of Faraday's Law. Note that you can ignore H since it is constant and has zero derivative in your expression above, leaving the time-varying portion [tex]\vec{B}(t)=\mu_0 \vec{M}(t)[/tex] From this you can easily compute the flux.
thanks all, specially Hassan and marcusl.
[itex]\vec{B}(t)=\mu_0 \vec{M}(t)[/itex]
But I have a problem.
Unit of B shoud be Tesla but in above formula is not.
Unit of M is [itex]\frac{J}{T}[/itex], and unit of [itex]\mu_0[/itex] is [itex]\frac{V.s}{A.m}=\frac{T}{A.m}[/itex], and then unit of B in above relation is [itex]\frac{J}{A.m}=\frac{V.A.s}{A.m}=\frac{V.s}{m}= \frac {T}{m}[/itex].
Have I a mistake?Where is my mistake?
thanks all again.
thanks all again.
You're welcome simorgh,
In SI units, the unit of M is A/m or J/(Tm3). I think you are confusing magnetic moment and magnetization. Magnetization is the volume density of magnetic moment.
OK. But in this situation unit of B in mentioned relation will be [itex]\frac{T}{m^4}[/itex]!
Should we change relation and use other relation?
The units are fine,
unit of μ0: [itex]\frac{T.m}{A}[/itex]
unit of [itex]M[/itex]: [itex]\frac{J}{T.m^{3}}[/itex]
then
unit of [itex]B= \frac{T.m}{A} \frac{J}{T.m^{3}}=\frac{J}{A.m^{2}}= \frac{Wb}{m^{2}}=T[/itex]
Hassan2 said:
The units are fine,
then
yes, you are right, thank you.
In the NMR, we have a sample that mentioned magnetization is generated from it.
Unit of volume that you use in magnetization is volume of space (and not volume of sample), isn`t it?
If it is, then magnetic moment and magnetization will increase if we increase volume of sample (of course if total volume of sample be less than unit of volume), isn`t it?
[itex]M=\frac{\sum \mu_{k}}{\Delta V}[/itex] as [itex]\Delta V\rightarrow 0[/itex] ( not really zero but a small volume)
where [itex]\mu_{k}[/itex] is the atomic magnetic dipol and [itex]\Delta V[/itex] is a small volume around the point for at which the magnetization is defined. With this definition, M does not depends on the total volume but it depends on how parallel the atomic moments of the volume are. Since [itex]\mu_{k}[/itex]s have equal magnitude, under a strong field all become parallel and M reaches its maximum which is called saturation magnetization. Beyond saturation, M does not depend on the applied field.
The equations hold independently of the geometry of the sample. In NMR, the sample will at best be weakly paramagnetic and the sample size is macroscopic so that the equations of linear electrostatics are applicable. So the change of magnetic flux can be expressed in terms of M and the problem is solved inside the sample. However if the sample does not fill the entire coil, the field in the surrounding vacuum has to be taken into account, and, as magnetization vanishes there, can't be expressed in terms of magnetization. Rather, one would have to solve Helmholtz equations with the magnetization at the sample surface as boundary conditions.
For a rectangular prism of iron, when it is magnetized along the long side, the flux density would be larger than if it was magnetized along one of the shorter sides with the same uniform magnetization. Doesn't it hold in NMR?
Also, I'm curious to know what are typical values of [itex]\mu_{r}[/itex] for NMR samples.
I am not sure if I understand your setup. Do you mean the irron being magnetized by bringing the prism into a homogeneous extended B field?
Yes. We have such a thing as demagnetizing factors which relates M and the field arising from M. This field is added to the applied field and the sum appear in Maxwell's equations. The factors depend on geometry.
Yes, I know, but that is irrelevant for the material equations which relate H, M and B.
It is a problem of solving the Maxwell equations, i.e. finding the magnetization if the field is known e.g. at large distances. In an initial homogeneous field, a homogeneous magnetization will only arise if the object is ellipsoidal.
In the problem given this problem does not arise as M is assumed to be known.
Yes, the material law doesn't depends on geometry but the second equation
[itex]B=\mu_{0}(M+\frac{M}{\chi})[/itex] is debatable because in general there relation between M and H at a point is not [itex]M=\chi H[/itex] but [itex]M=\chi H_{app}=\chi (H-H_{d})[/itex] where [itex]H_{d}[/itex] is the stray field arising from magnetization istelf and depends on geometry. In other words, susceptibility is the response to applied field while H in Maxwell equation is the sum of the applied field and the stray field.
I have never seen that although there are different empirical material equations depending on the problem at hand. Usually you would chose a material equation for the dependence of M on H (or H_d or whatever) which is as linear and local as possible.
Do you have a reference where M is explicitly taken to depend on H_{app} and not on H?
simorgh said:
Hi,
Question:
Back to the original question. The magnetization in NMR spectroscopy is tiny even in the largest machines. Hence any non-linearities can be neglected. Hence [itex]dB=\mu_0 dM_x/dt\; dt[/itex].
OK. I should agree with you. Although the definition and measurement of magnetic susceptibility is based on applied field, there is another thing as volume magnetic susceptibility which relates the M and H. I was thinking in the realm of micromagnetics where less number of experimental parameters are used.
Thanks.
I confess I don`t understand about argument #14 to #23.
It is better to define problem with more detail.
In the NMR, we take sample in the static hemogenious magnetic field ([itex]B_0[/itex]). This cause appear Zeeman effect and because of Boltzmann distribution a net magnetization ([itex]M_0[/itex]) will appear parallel to direction of [itex]B_0[/itex] (say z axe).
magnitude of this magnetization is:
[itex]M_0=\frac{n_0 \gamma_n^2 \hbar^2 B_0}{4 K_B T}[/itex]
that [itex]n_0[/itex] is the number of nuclei per unit of volume, [itex]\gamma_n[/itex] is gyromagnetic ratio, [itex]K_B[/itex] is Boltzmann constant and T is temprature.
By an alternative magnetic field ([itex]B_1(t)[/itex]) irradiated in a direction perpendicular to axe of [itex]B_0[/itex], one can change direction of this net magnetization and when [itex]B_1[/itex] is off, the net magnetization will return to its previous state by a precessing movement. Note that x component of [itex]M_0[/itex] decays with below formula:
[itex]M_x = M_0 e^{\frac{-t}{T_2}}[/itex] where [itex]T_2[/itex] is transverse relation time There is a selnoid in xy plane (say in x direction). This magnetization will induce a current in the selnoid.
of sample.
1. How can I calculate this current?
2. If we increase volume of sample, then magnetization (and induced current) will increase?
In general, even magnetostatics (or slowly changing magnetic fields) is quite a difficult problem as the magnetization acts as the source of a magnetic field of its own (thats the field you are interested in) which induces magnetization which may change the magnetic field, and so on. These is the influence of the stray fields, Hassan2 was mentioning.
However, in your case they are completely irrelevant as the factor of proportionality between M and B is tiny (namely it is the factor [itex]\chi=\frac{n_0 \gamma_n^2 \hbar^2 }{4 K_B T}[/itex] from your formula below). Hence you can calculate B(t) =M(t)/χ. You can then calculate the magnetic flux Phi by simply multiplying with the volume of the sample. By the formula from your first post you get the induced current from the time derivative of the flux.
simorgh,
Sorry for getting off the topic.
Now the problem is clear and unlike what I thought, the change in M is not due to the change in the applied field ( hence the susceptibility becomes irrelevant) but it's due to damped precession of M during the relaxation process.
My approach is simple but the result is ( in general ) different from what DrDu says.
From your setup, M0 is known. Suppose the sample is a cylinder with radius of 1cm and height of 10 cm and the axis of the cylinder is along x axis. Your cylinder now is a permanent magnet with a uniform magnetization which is changing by time. Are your familiar with such problems where we need to find the magnetic field inside the magnet due magnetization of the bar? If yes, then just find B on the plane of the coil and the surface integral of B is the flux. The flux rate is emf induced in the coil.
It's a known fact that in general, the field generated by a permanent magnet both inside and outside the magnet depends on its geometry. For example for a spherical sample inside the sample [itex]B= \frac{2}{3}\mu_{0}M[/itex] while for an infinitely long cylinder magnetized along its axis [itex]B=\mu_{0} M[/itex]. For an arbitrary shape the relation becomes very complicated.
However if the cylinder is long enough , the field inside the magnet approaches its maximum [itex]B_{x}=\mu_{0} M_{x}[/itex] ( as marcusl said), regardless of the height . If the sample is fit inside the coil, the induced emf then becomes B multiplied by the cross-sectional area of the sample ( which is assumed equal to the coil area).
Hassan, you are completely right.
  • · Replies 25 ·
13K
  • · Replies 42 ·
