Answer in the back of the book is wrong?
  • Thread starter Thread starter Jamin2112
    Book
Jamin2112
I'm tutoring a kid in high school Calculus and his book gives an answer of (25√3)/4 for the following question.
A trough of length 6m has a uniform cross-section which is an equilateral triangle with sides of length 1. Water leaks from the bottom of the trough at a constant rate of 0.1 m3/min. Find the rate at which the water level is falling at the instant when the water is 20cm deep.
What is YOUR answer? Why do you think the book'a answer is wrong?
The area of an equilateral triangle is A=h2/sqrt(3) if h is the height when it is standing on one of its tips
The volume of the trough in question is defined by the equation V=6*A=6*h2/sqrt(3)
dV = (12/sqrt(3))*h*dh by differentiation
dh = dv*(sqrt(3)/12)*(1/dh)
dh = sqrt(3)/24 when dv=0.1 and h=0.2.
Is this shoddy arithmetic by me, or am I a failure of a tutor, or both?
I agree with your answer.
I'm getting the same as you for m/min (except that dh/dt is negative). Are those the units requested?
100 litres per minute is quite the leak.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
