Answering 6th Grade Physics: Explaining School Bus Jerk Using Newton's Laws
  • Thread starter Thread starter shayes928
    Bus School
Passengers on a school bus are not jerked backward when the bus stops; instead, they are pushed forward due to inertia. This phenomenon is explained by Newton's First Law of Motion, which states that an object in motion remains in motion unless acted upon by a force. When the bus comes to a sudden stop, passengers continue moving forward until the bus seats exert a force to change their motion. Conversely, if the bus suddenly starts moving, passengers may feel a backward jerk as they remain at rest while the bus accelerates. Understanding these principles clarifies the effects of motion and inertia in everyday scenarios.
shayes928
The following question appeared on my son's 6th grade physics test recently:
"Why are passengers on a school bus jerked backwards when the bus comes to a sudden stop? Explain using Newton's laws of motion."
I was just wondering what a good answer to this might be.
Thanks in advance!
6th grade?
The statement you wrote above is wrong though. The passesngers on the bus will NOT be jerked backward when the bus comes to a sudden stop.
Either they will be jerked forward when the bus comes to a stop (assuming the bus was moving forward to begin with), OR they will be jerked backward when the bus suddenly starts.
The answer lies in Newton's First Law of Motion: (Sixth grade version)
An object at rest will remain at rest unless a force causes it to move; AND an object in motion will remain in motion (at the same speed in a straight line) unless a force causes it to change its motion.
The passengers are not really "jerked." They simply remain in motion while the bus stops, or they remain at rest while the bus starts. The passengers are waiting for the bus seats to exert the force that will change their own motion.
Because this schoolbus was traveling in reverse!
They are jerked backwards by a sudden start, not a sudden stop. Objects in motion tend to stay in motion; objects at rest tend to stay at rest. When the bus starts moving, the children tend to stay at rest, and are thus jerked back relative to the bus.
Njorl
