Smaller Antennas, Higher Frequencies: The Need for Size Reductions
Antenna size is inversely related to frequency, meaning higher frequencies correspond to shorter wavelengths and allow for smaller antennas. For effective transmission of electromagnetic waves, the antenna must match the transmitter, which is crucial for radiating power efficiently. As antennas become smaller relative to the wavelength, their radiation resistance decreases, complicating power transmission. Low-frequency antennas, such as those used for long-wave radio, require large structures to be effective, while high-frequency antennas, like those in mobile phones, can be compact and efficient. Understanding these principles is essential for optimizing antenna design across various applications.
Noudi
Why antenna needs to be smaller in size with higher frequencies (EM waves)? please
Because antenna dimension is proportional to wavelength.
Wavelength = speed of light / frequency
Welcome to the PF.
This introductory article should also help: http://en.wikipedia.org/wiki/Antenna_(radio )
:smile:
Thanks Dear.
Actually, it's rather the other way round. The antenna for a high frequency (short wavelength) can be small. For low frequency, they need to be big.
When you want to launch an EM wave into space, you need to 'match' your transmitter to the antenna - in order to get the power out into space. The mechanism that causes power to be radiated (which is what the whole thing is about) ls the equivalent to a resistance for the transmitter to drive into. As the antenna gets to be a small fraction of a wavelength, this (radiation) resistance gets lower and lower - the limit being a short circuit. It is very difficult to put much power into an extremely low resistance because all the power gets dissipated in the transmitter and the connecting cable. Hence, to transmit Radio Signals at 198kHz (BBC Radio 4 Long Wave @ Droitwich) the transmitting antenna (the actual wires that radiate - not just the tower height) is a T shape with the vertical section about 100m high. Even with this massive structure, the antenna is not very efficient and a significant amount of power just warms up the metalwork and the ground nearby. For your Mobile phone, which uses wavelengths of much less than 1m, the antenna can be made to fit inside the case quite easily and is a pretty efficient design (for battery like).
To get good directivity, you need antennae that take up several (or even hundred) wavelengths. Hence the massive 'dishes' for radio astronomy.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
