xxChrisxx said:
This is wrong, and as this is clearly a real case bum information may set the OP off in the wrong direction.
Please re-read what I wrote again, pay particular attention to: "(there was nothing your company could have done to prevent it)".
Employers are obliged to ensure a safe working environment even (especially is probably more accurate) when working off site. This usually extends to correct training, risk assesments of the job, audits of the site, etc. If an employee is injured off site, it's most certainly the reponsibility of the company that he is employed by, as he was there on their behalf.
However, providing the safe working environment is the responsibility of whoever owns the site.
Correct, which is why I put that little caveat in my previous post.
If your employer did everything they could and followed the laws correctly, then there is no recourse on them. This is why you keep H&S records to show you are following the law when things go wrong.
If they had the necessary risk assessments of the site and they showed it as safe, it then falls on the site owner to prove the problem (in this case the hole) was there before that RA was conducted - proving that company is actually responsible and negligent (this doesn't absolve them of responsibility for not adhering to the rules).
H&S is a tricky business. The company I worked at went to great lengths to follow every single H&S procedure and keep it recorded. Every time something went wrong they just showed this to H&S, proved they had done everything within their power, and that was pretty much the end of it.
I'd also note that there are cases when performing RA's and other procedures just isn't possible. This is where things get really messy, but under these circumstances it would be between both site owner and your company. It's part of the reason why the law says "as far as possible" when referring to the employers responsibility to make sure it's safe.
So as much as the buck stops with who ever owns the site, it's everyones problem. I can only assume this is a small company the OP works for, because there should be a health and safety officer who would have told him this and his manager wouldn't have been so dismissive.
Again, as above. To me this sounds like a small company (as you note) who doesn't follow all the necessary procedures. In which case, my little note above comes into play as the company
hasn't done everything possible.
OP if the H&S conditions were truly bad why didn't you raise it before beginning any work on the site?
The obvious question (at least for me). See the last paragraph of my previous post, it sums out my view on it.
