Anyone here understands how a [overhead fan works?]
  • Thread starter Thread starter Meggriffin
    Fan Works
A discussion on the mechanics of overhead fans explores the hypothetical scenario of a fan reaching 90% the speed of light in a closed room. It concludes that the air would perceive the fan as a solid object, and the extreme speed would likely cause catastrophic effects, such as induced fusion, potentially evaporating the building. The conversation emphasizes that for practical air flow effects, speeds should be more realistic, around the speed of sound. Theoretical implications of such speeds on fan blades and air dynamics are also considered. Overall, the discussion highlights the absurdity and danger of extreme speeds in everyday objects.
Meggriffin
Ello, does anyone here understand how a standard overhead fan and air flow works? If so, what would happen if you're just chilling in your room with the door closed,windows shut and fan off, then the fan just speeds up to around90% thespeed of light for a second. Would that kill me, suck me through the roof/force me through the ground? Just wondering.
Probably.
"0.9 c?" Nothing --- the air in the room would "see" the volume swept by the fan as a solid circular plate.
What if is a great site answering these sorts of questions. This one will give you an idea what an everyday object would do close to c;
https://what-if.xkcd.com/1/
In addition, we could ask how the fan blades could stay attached to the fan long enough. Induced fusion is enough to evaporate the whole building in either case, but if we start with a few blades moving at up to 90% the speed of light we get several plasma clouds moving in different directions!
To get an effect on air flow alone, we have to keep the speed more realistic (of the order of the speed of sound).
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
