How can I add an indicator light to my OPB745 sensor?
  • Thread starter Thread starter oslaught
    Sensor
The OPB745 sensor lacks an indicator light to show activation status, with voltage readings indicating object detection. To connect an LED as an indicator, a comparator circuit is recommended to buffer the output of the sensor's phototransistor. This setup allows the LED to be driven reliably, with attention to trip levels and positive feedback for hysteresis. Users are encouraged to consult the sensor's datasheet for detailed specifications. Implementing this circuit will enable effective visual feedback for the sensor's activation.
oslaught
Hi all,
i got e above mention sensor for my mini project. encounter a problem is that the sensor does not have an indicating light that show if the sensor is activated.
i've measure between the GND and the signal output which gives a 4.8V when nothing is sense. when there's object infront, the voltage will drop to ~2.2V. I've try connecting a 5V led between it, but does not work as the output signal doesn't give a pure GND.
like to know if there's anyway i can connect the led as a indicator for the sensor. maybe a circuit?
thank you all.
Welcome to the PF. It helps us to help you if you provide a link to the datasheet for the part that you are asking about. I used google and then Mouser to get this one:
http://www.optekinc.com/pdf/OPB745.pdf
You need to buffer the output of this reflective photosensor in order to drive an LED reliably. Just put a comparator at the output of the Darlington phototransistor, and drive the LED with the output of the comparator. Be sure to design your comparator circuit with good margin on the trip levels, and with positive feedback to provide hysteresis.
Hi berkeman. thanks for finding the link. yup, that's the sensor.
I'm more of a electrical guy, not so into electronic. Possible to explain more on what/how to make it works. meanwhile I'll ask my friend about it too.
Thanks alot..
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
