AP Physics B free response practice questions
The discussion focuses on a physics problem involving two 10-kilogram boxes connected by a string over a frictionless pulley, with one box on an inclined plane. Participants are asked to determine the frictional force acting on the box on the plane, the mechanical energy converted into thermal energy when the box slides down, and the kinetic energy of the box at the bottom. The importance of showing attempts at solutions before seeking help is emphasized, as community members prefer to assist those who demonstrate effort. The conversation highlights the need for understanding key physics concepts, such as friction and energy conservation. Engaging with the problem actively is crucial for effective learning in AP Physics B.
Sudhakar_alla
two 10-kilogram boxes are connected by a massless string that passes over a massless frictionless pulley. The boxes remain at rest with the one on the right hanging vertically and the one on the left 2.0 meters from the bottom of an inclined plane that makes an angle of 60° with the horizontal. The coefficents of kinetic friction and static friction between the left-hand bax and the plane are 0.15 and 0.30 respectively.
fk = UkN
N = mg
c) Determine the magnitude of the frictional force acting on the box on the plane. The string is then cut and the left-hand box slides down the inclined plane.
D) determine the amount of mechanical energy that is converted into thermal energy during the slide to the bottom.
E) Determine the kinetice energy of the left hand box when it reaches the bottom of the plane.
If someone could explain how they got the answers it would help a lot. Thanks.
Please show us your attempt solution. Nobody here is going to sit around and explain how to do every question step-by-step unless you've made an honest effort to try the questions yourself.
