AP Test on Force Corrections (3 of them, but only one at a time)
The discussion centers on calculating the frictional force acting on a 2-kilogram block sliding down a 30-degree incline with an acceleration of 2 meters per second squared. The initial approach incorrectly calculated the frictional force using the equation F_f = m (a + gsin30), resulting in an incorrect answer of 13.8. The correct formulation is F_f = m (-a + gsin30), leading to a final answer of 5.8, which matches one of the multiple-choice options provided.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of free body diagrams and force components
  • Familiarity with trigonometric functions, specifically sine
  • Basic principles of friction in physics
  • Study the derivation of forces on inclined planes in physics
  • Learn about the role of friction in motion and its calculations
  • Explore advanced applications of Newton's laws in different scenarios
  • Review trigonometric identities and their applications in physics problems
Students studying physics, particularly those focusing on mechanics and forces, as well as educators looking for examples of problem-solving in dynamics.
RustyComputer
A 2-kilogram block slides down a 30 degree incline as shown above with an acceleration of 2 meters per second squared. The magnitude of the frictional force along the plane in most nearly:
Then some multiple choice answers.
F=ma
So the first thing I did was draw a free body diagram, with all three forces present. Force of friction going opposite of the direction the box is going, normal force perpendicular from the surface, and mass times gravity going straight down.
Then I tilted the diagram 30 degrees, to make the force of friction and normal force straight vertical and horizontal and put mg at an angle of 30 degrees to the left from it's initial point.
After that, I made a right triangle to find the horizontal and vertical components of mg, and wrote mg as the hypotenuse, mg_x as the horizontal component, and mg_y as the horizontal component.
Then here are the equation stuff I did.
F_f - mg = ma
F_f = ma + mg_x
F_f = ma + mgsin30
Then I plugged everything in,
F_f = 2(2+9.8sin30)
And came up with the answer
F_f = 13.8
But the problem is that there are no answers close to my solution with the given. So what I would like to know for this problem is, where did I go wrong?
This expression is wrong. Downward force in mgsinθ. Frictional force acts in the upward direction. So the net force
mgsin30 - F_f = ma
So the correct way to go about that is:
mgsin30 - F_f = ma
F_f = - ma + mgsin30
F_f = m (- a + gsin30)
Then plugging in:
F_f = 2 (- 2 + 9.8sin30)
F_f = 5.8
And as it turns out, that is a multiple choice answer, and it is correct.
I'll have the next question up in a bit...
