Apparent magnitude of a binary star system
To calculate the apparent magnitude of a binary star system with a hot main sequence star and a red giant, the distance to the system is approximately 833.65 parsecs based on the given parallax. The apparent magnitudes cannot be directly added; instead, they must be converted into intensities for accurate summation. The formula b1/b2 = 2.512^(m2-m1) is relevant for this conversion. The discussion emphasizes the importance of understanding the relationship between magnitude and intensity in binary systems. Proper calculations will yield the correct apparent magnitude of the binary star system.
~ZeroPoint~
A binary star system consists of a hot main sequence star (m=0.5m) and a red giant (m=1.2m), the parallax of the system is p=0.0012". Calculate the apparent magnitude of the system.
I have b1/b2 = 2.512^(m2-m1) and p=1/r
I've already calculated the distance from the system to the Earth (~833.65pc) and I know that I can't simply add the apparent magnitudes.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
