Apparent weight on an elevator. Magnitude of its acceleration?
The discussion revolves around calculating the acceleration of an elevator based on the apparent weight change experienced by a person standing on a scale. The individual weighs 160 lb but the scale reads 123 lb, indicating the elevator is accelerating downwards. The correct approach involves using the difference in weight to determine acceleration, leading to a calculation of approximately 7.234 m/s². Participants clarify that the elevator's acceleration is less than gravitational acceleration, suggesting it is slowing down while moving upwards. The conversation emphasizes collaborative problem-solving and the importance of accurate calculations in physics.
WPCareyDevil
You are standing on a bathroom scale inside an elevator. Your weight is 160 lb, but the reading of the scale is 123 lb.
(a) What is the magnitude and direction of the acceleration of the elevator?
? m/s2
(b) Can you tell whether the elevator is speeding up or slowing down?
do not know
slowing down
speeding up
weight=mg
ma=ma
160lbs = 75.574kg
123lbs: 55.792kg
g= 9.8ms
obviously, the elevator is accelerating downwards, reducing his apparent weight.
his weight when on the ground is 740.625N.
So, 740.625=55.792a
a=13.27475. The question is asking for magnitude, but there is no x component so sqrt(a^2) would still be 13.27475
Obviously, this isn't correct. Can someone point me in the right direction?
? m/s2
do not know
slowing down
speeding up
weight=mg
ma=ma
160lbs = 75.574kg
123lbs: 55.792kg
g= 9.8ms
So, 740.625=55.792a
If it was slowing down while going up it could read the same. All you know is acceleration is less down on the scales.
Ahh, you're right. That makes sense - I didnt think of that.
I tried using -13.27, and subtracting 9.8. What am I missing with the calculation?
Thank you for the tip!
WPCareyDevil said:
Ahh, you're right. That makes sense - I didnt think of that.I tried using -13.27, and subtracting 9.8. What am I missing with the calculation?
You can divide by like equations.
9.8/160 = x/123
I know the units are silly but they cancel as long as your acceleration is to be in m/s2
The difference then with 9.8 must be the acceleration in the same direction as g.
Thank you so very much!
I was able to figure it out after a bit of tweaking.
This place is the best =D. I've tried to go through answering peoples questions- but I find that I either cannot answer them well enough, or someone has already beat me to it. I'll try to give back as much as I can
You're welcome. Glad that it helped. All contributions welcome.
Cheers.
WPCareyDevil said:
So, 740.625=55.792a
a=13.27475.
Maybe I'm wrong, but I think it should be 546.762=75.574a so a=7.234.
