Applications of Faraday's Law: Deflection of Pointer in a Magnet-Coil System
When the power supply switch is closed, the circuit becomes complete, allowing current to flow through the coil. Initially, there is no deflection of the pointer because the current is not yet established, but as time progresses, the inductor's current will rise, leading to a gradual change in magnetic flux. This change will eventually cause the pointer to deflect due to the induced electromotive force (emf) according to Faraday's Law. As the system reaches a steady state, the inductor's emf will drop to zero, and the pointer will stabilize in a horizontal position. The discussion highlights the relationship between current flow, magnetic flux changes, and the resulting pointer deflection in the magnet-coil system.
jackd
A magnet is suspended so that it is free to swing above a coil that is connected to a power supply. A pointer has been attached to the magnet so that a small swing of the magnet will result in a large deflection of the pointer. When there is no current through the coil, the magnet is horizontal and the pointer is vertical.
What is the deflection of the pointer (if any) when the switch on the power supply is closed?
What happens to the pivot as the current through the coil is varied?
Faraday's law = E = -d(magflux)/dt
magnet flux = BAcos(theta)
When the switch on the power supply is closed, this means that there is no current. This means that there will be no deflection of the pointer.
Is this correct? What does it mean by the switch is closed?
When the switch is closed, the circuit is complete. You have interpreted it incorrectly.
okay, thanks!
so if the switch is closed, this means that the circuit is complete. right after the switched is closed, no current should flow but the rate of change shouldn't be zero (this is because inductor current can't change instantaneously).
but after some time has passed, the inductor current, resistor current and resistor voltage will rise from zero. because the power supply emf should be constant, the magnitude of the inductor emf should drop... eventually the whole circuit should reach a steady state (the rate of change approaches zero) & the inductor emf should be zero...
is this right? how does this affect the pointer in this device? should the pointer go horizontal?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
