Approaching Infinity: Solving Limits with the Conjugate Method
  • Thread starter Thread starter curiouschris
    Infinite Limit
The discussion revolves around evaluating the limit as x approaches infinity for the expression lim x → ∞ (√(x² - 3x) - x). The subject area is calculus, specifically focusing on limits and the use of the conjugate method to simplify expressions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the initial steps taken using the conjugate method and express confusion about how to proceed after simplifying the expression. There are attempts to factor and manipulate the square root, with some participants questioning the validity of certain algebraic steps and the assumptions made about x.
The conversation is ongoing, with various participants offering insights and corrections to each other's reasoning. Some guidance has been provided regarding the manipulation of terms, but there is no explicit consensus on the next steps or the overall approach to the limit.
Participants note the challenge of understanding the algebra involved, particularly in relation to the behavior of the expression as x approaches infinity. There is also mention of the need for a solid grasp of basic algebra to tackle the problem effectively.
curiouschris
Hi I am trying to help my son with his math course
(disclaimer: I have done very little calculus myself)
lim x [tex]\rightarrow[/tex][tex]\infty[/tex] [tex]\sqrt{x^2-3x}-x[/tex]
That was hard hope you don't mind if I don't use latex. I looked at the samples but the preview never rendered what I expected :(
We got this far using the conjugate
= (sqrt(x^2-3x)-x)(sqrt(x^2-3x)+x) / (sqrt(x^2-3x)+x)
= (-3x) / (sqrt(x^2-3x)+x)
I don't know where to take it from here. if I try to factor out the x's All I get is -(0/0) obviously wrong
Any help would be gratefully appreciated.
CC
Try factoring sqrt(x^2-3*x)=sqrt(x^2*(1-3/x))=sqrt(x^2)*sqrt(1-3/x). Any ideas where to go from there?
Sorry I am missing something (please remember I am trying to help my son, so anything I learned was eons ago)
I don't see how sqrt(x^2-3*x) becomes sqrt(x^2*(1-3/x))
of course once it does sqrt(x^2) = x
x^2-3*x=(x^2)*(1-3/x). Just multiply (x^2)*(1-3/x) back out to see why. And sqrt(x^2)=x isn't quite true. sqrt(x^2)=|x| is better. No problem with asking more questions.
curiouschris said:
To see how far I have got I understand the beginning of example 14 on this page, but I get lost at the "factor out x" part
http://www.analyzemath.com/calculus/limits/find_limits_functions.html
CC
That's pretty much the same as this problem. Let's just push through on this one and you shouldn't have any problems with example 14.
ACHTUNG: This post contains some wrong parts in LaTeX I am not able to correct. Please jump it...
When you use the conjugate, the objective is to eliminate all the disturbing x's floating around.
If I have understood your initial steps, the limit should look like this (after using the conjugate technique):
[tex]\lim_{x\rightarrow \infty}\displaystyle \frac{-3x}{\sqrt{x^2-3x}+x}[/tex]
Extract the highest terms from the denominator as suggested:
(the lower part of the fraction is:)
[tex]\sqrt{x^2-3x}+x=(x^2-3x)^{1/2}+x=[x^{2}(1-\frac{3x}{x^2})]^{1/2}+x=|x|(1-\frac{3}{x})^{1/2}+x[/tex]
[tex]\sqrt{x^2-3x}+x=x^{2/2}(1-\frac{3}{x})^{1/2}+x=|x|[\sqrt{1-\frac{2}{x}} +1}][/tex]
Now try the limit and check if things get better. I hope the passages are clear.
The signum |x| is required,isn't it?
Edit: I took the wrong exponent at the beginning. I do not understand why the edit function does not work properly with me. Really sorry, I did not want to make a mess... My next post should bring a better version of this one.
[tex]\lim_{x\rightarrow \infty}\displaystyle \frac{-3x}{\sqrt{x^3-3x}+x}[/tex]
[tex]\sqrt{x^3-3x}+x=(x^3-3x)^{1/2}+x=[x^{3}(1-\frac{3x}{x^3})]^{1/2}+x=x^{3/2}(1-\frac{3x}{x^3})^{1/2}+x[/tex]
[tex]]\sqrt{x^3-3x}+x=x^{3/2}(1-\frac{3}{x^2})^{1/2}+x^{3/2}x^{-1/2}=x^{3/2}[\sqrt{1-\frac{2}{x^2}} +\frac{1}{\sqrt{x}}][/tex]
Why did you substitute x^3 for x^2 in sqrt(x^2-3x)? I don't think this is making things clearer.
A correction to my previous post.
[tex]\sqrt{x^2-3x}+x=x^{2/2} (1-\frac{3}{x})^{1/2}+x=|x|[\sqrt{1-\frac{3}{x}} +1}][/tex]
Sorry guys had to go to bed after my last response am doing this from work shhh...
Hmm.. the latex renderer seems to aggressively cache latex so it won't re-render it even if the terms have changed.
how do we get from...
[tex]x^{2/2} (1-\frac{3}{x})^{1/2}+x[/tex] to [tex]|x|[\sqrt{1-\frac{3}{x}}+1}][/tex] ?
I don't get where the [tex]+1[/tex] comes from [tex]\sqrt{x^2}[/tex] becomes [tex]|x|[/tex] (thanks dick) but randomly replacing the x with 1 seems wrong
What intermediate step am I missing?
CC
CC
Well, he went from sqrt(x^2) to |x|, then we can assume x is positive (it's heading toward positive infinity), so we can substitute |x| with x. Then we get...
[tex]x \sqrt{1-\frac{3}{x}} + x[/tex]
Which we then factor out the x from both terms to get...
[tex]x \left(\sqrt{1 - \frac{3}{x}} + 1\right)[/tex]
Thanks that was the last part of the problem. When I get a few minutes I am going to post the complete work-through. hopefully all this effort you have gone to to help me understand, will help someone else.
The main lesson I have learn't is my sons not going to get through this course unless he scrubs up on his basic algebra. Dads not a great deal of help, its been too long for me and I no longer have the intuition that only comes with practice.
Ta
CC
Good luck, and I hope your son brushes up on the algebra well!
  • · Replies 20 ·
