Appropriate units for temp problem
  • Thread starter Thread starter thebigskysky
    Units
The discussion revolves around determining the appropriate units for heat transfer (h) in a given temperature equation. The equation is analyzed for homogeneity in units, leading to the expression h = (pcL/t). Participants express confusion over the resulting units, questioning the validity of the calculations and the interpretation of the exponential term. Clarifications are made that the argument of the exponential must be unitless, emphasizing the importance of dimensional analysis in the equation. Overall, the conversation highlights the complexities of unit conversions in thermal dynamics.
thebigskysky
(T-T envir)/(T int - T envir) = exp (-(2h/pcL)t)
T = temp (°C)
h = heat transfer
p = density (kg/m^3)
c = specific heat (J/Kg * K)
L = plate thickness (m)
t = Time (s)
What are the appropriate units for h? Show all steps... (equation is homogenous in units)
(°C-°C) / (°C-°C) = exp(-(h/(Kg/m*m*m)(J/Kg*K)(m)) s
temp/temp = 1
(kg/m*m*m)(J/kg*K)(m) = exp (-h * s)
(m*m*J*K) = exp (-h * s)
(m^2)(JK) / s = -h
- (m^2)(JK) / s = h ?
heat transfer = negative meters squared time joules time kelvin all over seconds ?
seems a little weird to me... what did i do wrong... ty guys
Positive or negative does not matter, it is the same units. If the temperature outside is -10 deg C or +35 deg C, it is still given in deg C.
The third line of your solition does not make sense. Why the exp on the right hand side?
The argument of the exponential has to be unitless.
[-(2h/pcL)t] = 1
[h] = [pcL/t] = ...
The result certainly looks odd. You can still write J as combination of other units, but that changes little.
