Approximating logarithmic series
The discussion revolves around the approximation of logarithmic series, exploring the validity of certain mathematical expressions and the implications of variable substitutions. Participants engage in examining specific cases and the conditions under which the approximations hold, with references to external materials for clarification.
  • Some participants question the feasibility of the approximation, noting inconsistencies in dependencies on variables n and h.
  • Concerns are raised about the interpretation of logarithmic bases, particularly whether the logarithm is base-2.
  • Participants discuss the implications of changing summation indices and how this affects the equality presented in the original question.
  • There are references to external links that illustrate similar mathematical transformations, with some participants expressing confusion over differing notations and contexts.
  • One participant points out a potential error in the original equation regarding the upper limit of summation.
  • Clarifications are made about the meanings of certain symbols and terms used in the referenced materials.
Participants express differing views on the validity of the approximations and the correctness of the equations presented. There is no clear consensus on the conditions under which the approximations hold, and multiple interpretations of the mathematical expressions exist.
Limitations include potential misunderstandings of variable dependencies, the context of logarithmic bases, and the implications of variable substitutions in the summation process. Some participants indicate confusion over the notation and definitions used in the referenced materials.
22990atinesh
Can anybody tell me how this is possible
It looks to me as if it isn't possible in the first place. Who claims it is ? Any restrictions on n and h ?
I see a common factor n in front and then something on the left that depends on n, whereas the remainder on the right does not depend on n.
Please check this link
http://sarielhp.org/teach/2003/b_273/notes/12_recc.pdf
Well, that's a start. Any more things potential helpers should know ? Such as: lg means base-2 logarithm (contrary to what wolfram thinks)
I managed to find lectures 10 and 11 as well, but drown in the understanding what the symbols stand for. I don't have a good impression of the recursion tree and am surprised to see ##a## and ##b## disappear (into 2 and 2 ?) and to see ##f## disappear as well. On the other hand an ##H## appears but isn't explained and a ##L## is explained but does not appear [edit]ah, sorry: I see: L is the number of terms in ##T(n)##.
Is this supposed to hold for arbitrary "n" and "h"? If so we can check by taking specific values for n and h. If we take, say, n= h= 1, the formula becomes \frac{2}{log(2)- 0}= \frac{2}{1} which clearly is not true unless the logarithm is to be "base 2". Is that the case?
Formally, it looks like they replace the summation index ##i## by ##j=\lg n-i##, as that would give ##\sum_{j=\lg n-1}^1\frac{1}{j}##. Then they rename the summation index ##i##.
EDIT: sorry, that's for the equality on the first page in the linked pdf, not the equality in post 1. My confusion.
Actually I've seen lots of places where they have done it
See the below link at example the guy has done the same thing
http://clrs.skanev.com/04/problems/03.html
logarithm is base 2
The thing you posted is false. However, the specific step in the link is true. So please be careful when copying something next time.
Try to change variables ##i\rightarrow \log(n) - i##.
Note the subtle differences between Sariel and Skanev ! The former is a bit sloppy writing ##\lg(n/2) = \lg(n-1)## when he means ##\lg(n/2) = (\lg n-1)##.
And yes, Wolfram allows ##\lg## to be the base-2 logarithm, a sensible choice in algorithm analysis - so I was wrong to mope about that. Not used to the context, I am.
So: Picked up some of the vernacular, and Skanev subtask 5 helps out by being a lot more meticulous. Check it out (or do I have to spell it out ?)
[edit] ah, ##\mu m## was faster.
Yes, nothing wrong with it.
I was confused because the equality in the question and the somewhat similar equality in the linked pdf are different.
There appears to be an error in your equation. I looked up your reference and the upper limit is log(n)-1 not h-1. The equality results from replacing log(n)-i by i. All that does is doing the sum in the opposite direction.
Thanks Everybody I get it :)
17K
