Aqua regia and a damned simulator
  • Thread starter Thread starter rollcast
    Simulator
A chemistry simulator developed by a tech expert at the company malfunctioned when attempting to find the weakest solution of aqua regia capable of dissolving gold. The program froze during the process and later indicated the presence of ice in the simulation, which raised questions about the accuracy of its calculations. Richard, the user, speculated that the bond-making process in the reaction absorbed enough heat to freeze the solution, despite expecting the reaction to generate heat. The simulator, primarily designed for calculating acid concentrations to safely dissolve metals without damaging them, may not have been equipped to handle the specific case of gold in aqua regia, leading to unexpected results. Previous successful simulations with aqua regia did not involve gold, suggesting a potential concentration limit issue. The discussion highlights the limitations of chemical simulators and the importance of understanding the underlying chemistry when interpreting results.
rollcast
One of the tech wizards in my company came up with a chemistry simulator a few years back. It works great and is quite useful, however I ran it this morning to see if I could find the weakest possible solution of aqua regina I could make that would still dissolve gold.
The thing totally **** itself when I added the gold to the aqua regina solution, but when the program unfroze it said there was ice inside the simulation environment?? This thing isn't graphical so you just have to read the print outs and work from there.
The chemistry guy is off on holiday so I have had to search my memory of high school chemistry for answers and can only come to the conclusion is that the amount of bond making occurring in the reaction has absorbed enough heat from the environment to freeze the solution?
Thanks
Richard
Ps. The first simulation said that the lowest temperature was -190oc, this however could have been a localised anomaly
Chemistry news on Phys.org
Doesn't sound like something that can happen in this case. If anything, I would expect the solution to get hot.
I agree with Borek .. I think you have hit upon a question that the simulator wasn't designed to deal with. I am not sure how it works, but there is no general way to account for all possible cases in a chemical simulator, so it can only give sensible results for systems it is specifically programmed to deal with. Have you used it for gold in aqua regia (note spelling) before and gotten sensible results? If so, then you probably just ran up against a concentration limit or something, where the program went haywire without giving you a sensible error message.
One quibble with your post ... making bonds *releases* energy, so the result predicted by your simulator could only result from energy being absorbed from the solution to break bonds, to the point where the temperature dropped below the freezing point. As Borek said, I would expect the opposite to occur in your example, since the dissolution happens by a redox reaction, followed by a complexation reaction, both of which are exothermic.
Sorry about the mix up on the science of it, I only remember high school hazily.
The simulator was designed to work out concentrations of acids needed to dissolve metals from machined parts and not damage the finished piece, we have had a request to machine some probe tips for someone, the main body is made out of gold and the very tips are electrocoated with platinum, don't know what their for I work in management now and don't deal with the machining.
The aqua regia was needed to clean the pieces before they were plated. We had used it before with aqua regia but never with gold so this is were the problem is.
Thanks
Richard
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
