How to Solve for r and θ in a Circle's Minor Arc and Sector Area Problem?
In summary: A=\frac{1}{2}r^2\theta$. So, we have:A=\frac{1}{2}r^2\left(\frac{s}{r}\right)=\frac{rs}{2}\implies r=\frac{2A}{s}\implies\theta=\frac{s^2}{2A}Now we can plug in the given values for $A$ and $s$ to solve for $r$ and $\theta$.
ai93
54
The length of the minor arc of a circle is 10cm, while the area of the sector AOB is 150cm2.
a) Form two equations involving r and θ, where θ is measured in radians.
b) Solve these equations simultaneously to find r and θ.
Help to solve? Cant understand the question very well.
I think the arc length formula was
length=\(\displaystyle \frac{n}{360}\cdot2\pi(r)\)
\(\displaystyle \therefore10=\frac{n}{360}\cdot2\pi(r)\)
The question states, Form two equations involving r and θ, where θ is measured in radians.
So would we have to arrange the formula to find the r and \(\displaystyle \theta\)
Mathematics news on Phys.org
The formulas you want are:
Circular arc-length:
\(\displaystyle s=r\theta\tag{1}\)
Area of circular sector
\(\displaystyle A=\frac{1}{2}r^2\theta\tag{2}\)
Now, if we solve (1) for $\theta$, we find:
\(\displaystyle \theta=\frac{s}{r}\)
Now, substituting this into (2), we obtain:
\(\displaystyle A=\frac{1}{2}r^2\left(\frac{s}{r}\right)=\frac{rs}{2}\implies r=\frac{2A}{s}\implies\theta=\frac{s^2}{2A}\)
Now, just plug in the given values for $A$ and $s$. :D
Im finding trouble understanding the question.
"Form two equations involving r and \(\displaystyle \theta\)" Basically means transpose the formula or make the equation equal to r and \(\displaystyle \theta\)?
Since the arc length = \(\displaystyle s=r\theta\) (I thought arc length was length=\(\displaystyle \frac{n}{360}\cdot2\pi(r)\)?
r=\(\displaystyle s\theta\)?
For b) we just sub in the values? Where s is the length?
You are given values for the arc-length $s$ and the area $A$, and so you want to use the formulas relating $r$ and $\theta$ to these given values (which I gave as (1) and (2)) to be able to express both $r$ and $\theta$ as functions of $s$ and $A$ (which I did using some algebra), so that you can use these given values to determine $r$ and $\theta$.
Once you have $r$ and $\theta$ as functions of $s$ and $A$, it is simply a matter of using the given values to evaluate $r$ and $\theta$.
It's asking to make two equations for the length of an arc and the area of a sector. As long as your equations have \(\displaystyle r\) and \(\displaystyle /theta\) in them then you're fine for this step.
MarkFL has given you the equations you need (his TeX is also better than mine! (Smile))\(\displaystyle \displaystyle s=r\theta\tag{1}\)
\(\displaystyle \displaystyle A=\frac{1}{2}r^2\theta\tag{2}\)
As you see both of these equations have \(\displaystyle r\) and \(\displaystyle \theta\) in them so Part A of the question has been solved already :)
\(\displaystyle \frac{n}{360}\cdot 2\pi r\) is the equation for arc length where \(\displaystyle n\) is in degrees. Since the question asks for radians you want \(\displaystyle s = r\theta\). See the spoiler below for why they are equivalent
By definition a full circle has 360 degrees and $$2\pi$$ radians so you can say $$360^{\circ} = 2\pi$$ (we omit the c symbol for radians)
Your formula for degrees is $$s = \frac{\theta}{360} \cdot 2\pi r$$ but since we know that $$360^{\circ} = 2\pi$$ it can be subbed in
$$s = \frac{\theta}{2\pi} \cdot 2\pi r = r \theta$$ - the radian expression
Sub in the values given (10cm and 150cm²) for s and A respectively so you have two equations and two unknowns (\(\displaystyle r\) and \(\displaystyle \theta\)).
You can now solve simultaneously using either the substitution method MarkFL showed in post 2. He found \(\displaystyle \theta\) in terms of \(\displaystyle r\) which means he was able to substitute \(\displaystyle \frac{s}{r}\) wherever \(\displaystyle \theta\) appeared.
He did in terms of \(\displaystyle s\) in post 2 but if you find it easier you may use \(\displaystyle s=10\) for your example
Thanks this really did help :D
Beginning to understand this a lot easier.
Just a question on the last part.
How did you rearrange to get \(\displaystyle \theta\)?
It went from, \(\displaystyle A=\frac{1}{2}r^2\left(\frac{s}{r}\right)\) which I understand to \(\displaystyle =\frac{rs}{2}\)?
Divide through by $r$
\(\displaystyle \frac{s}{r}=\frac{\cancel{r}\theta}{\cancel{r}}\)
\(\displaystyle A=\frac{1}{2}r^2\left(\frac{s}{r}\right)=\frac{\cancel{r}\cdot r\cdot s}{2\cancel{r}}=\frac{rs}{2}\)
What is an arc length?
An arc length is the distance along the circumference of a circle or any curved object.
How is arc length calculated?
Arc length can be calculated by multiplying the angle (in radians) by the radius of the circle.
What is the formula for arc length?
The formula for arc length is:
Arc Length = (Angle in radians) x (Radius of circle)
Can arc length be negative?
No, arc length cannot be negative as it is a measure of distance and distance cannot be negative.
What units are used to measure arc length?
Arc length can be measured in any unit of length such as meters, centimeters, inches, etc.
  • General Math
  • General Math
