Arc welding plant power cut off
The discussion revolves around energy management in an arc welding plant, specifically addressing concerns about power consumption when the equipment is not actively in use. Participants explore potential solutions to minimize energy waste during idle periods.
  • One participant suggests that turning off the equipment when not in use could save energy.
  • Another participant argues that the equipment likely consumes minimal power while idling and may require cooling, thus questioning the need for concern.
  • A third participant notes that the welding equipment was left on for an extended period, indicating a lack of attention to power management by the workers.
  • One suggestion involves installing a timer to automate the power management process, turning the equipment off during weekends.
  • Another participant raises the question of whether the power consumption is significant enough to warrant action and whether there are valid reasons for keeping the equipment on.
Participants express differing views on the necessity and effectiveness of turning off the equipment. Some propose solutions while others question the significance of the power waste, indicating that the discussion remains unresolved.
There are uncertainties regarding the actual power consumption of the equipment during idle periods and the potential need for cooling. The discussion does not clarify the specific energy costs associated with leaving the equipment on.
lakmalp
I have an arc welding plant and I realized that I am wasting energy when it is not used but powered on. Can anyone please suggest a way to get rid of this problem?
That is, plant gets "active" when it is welding and is "idling" when it is not welding.
Ummmmm, turn it off? Seriously, unless you leave it on for hours before and after you are actually welding why worry? There is most likely a fan that cools the unit and it should be left on for this purpose for several minutes at least before you shut it off. It should draw a very minimum of power at idle.
I am not the one actually who use it. But the workers at my father's factory. They are not that concerned with turning it off when not in use. Last weekend it was on during the whole weekend. So, that's why I want to find a solution for this.
Can you put a timer on it? Set it to turn off on Friday at 5 and turn on when Monday rolls around.
  1. Have you confirmed that it is actually wasting enough power to actually care about?
  2. Have you checked to find out if there are good reasons for leaving it on?
  • · Replies 16 ·
  • · Replies 16 ·
