Are closed time like curves an inherent feature of rotating universe models?
Galteeth
This is a follow up to my previous question, as they appear that in both the Godel Metric and the Van Stockum dust
Perhaps a better way to put this is, could there be a model where you had rotation (maybe around a non-symmetrical axis?) and not get these CTCs?
On this old page by a guy who did his PhD thesis on rotating universes in GR, in the section "Time Traveling and Rotation of the Universes" he writes:
The rotation of the universe, i.e., the vorticity, is a local property. The closed time-like curve is a global feature. Accordingly the connection may be obscure. We don't have any concept of a universe rotating as a whole: The picture is complicated very much by the non-existence of a suitable global reference system; by the presence of shear and expansion; by the space-time curvature; and by the infinity of the universe.
There are rotating universes that do preserve causality. I am not aware of any non-rotating universe that violates causality.
He doesn't elaborate on that statement though (his name is Egils Sviestins, and http://www.isif.org/fusion07CD/Fusion07/pdfs/Fusion2007_1143.pdf seems to give an email for someone of that name, you could try contacting him). Also, in the later section "Is Time Traveling Possible in our Universe?" he writes:
In order to be able to travel to the past, three conditions should be fulfilled:
1. Einstein's General Relativity is a valid description of the universe.
2. The Universe has a suitable structure probably incorporating sufficiently fast rotation.
3. The practical difficulties can be overcome.
So it may have something to do with the rate of rotation, but the previous quote suggests that the exact connection between the type of rotation and the possibility of CTCs isn't easy to state.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
