Are Composite Airframes Like the 787 Prone to Long-term Failures?
  • Thread starter Thread starter hammertime
    Composite
The discussion revolves around the long-term reliability of composite airframes, specifically in the context of the Boeing 787, and whether they may experience failures similar to those of the de Havilland Comet. Participants explore concerns about material fatigue, manufacturing quality, and the evolution of testing methodologies in aviation.
  • Some participants question whether the 787 will need to undergo a "de Havilland Comet phase" to address potential long-term failures of composite airframes.
  • Others argue that advancements in technology allow for rigorous simulations to predict material behavior, suggesting that composite airframes will be safe once in operation.
  • Concerns are raised about the unpredictability of fatigue in materials, with one participant noting that composites do not exhibit fatigue in the same way as metals, implying that failures are likely to be design flaws identified during testing.
  • Some participants emphasize that modern quality control and extensive testing programs significantly reduce the risk of failures compared to historical practices during the Comet's era.
  • One participant with experience in composites highlights the complexity of composite materials and the potential for manufacturing errors, while also noting their superior strength-to-weight ratio.
Participants express differing views on the reliability of composite airframes, with some asserting confidence in modern technology and testing, while others maintain concerns about potential long-term failures and the unpredictability of material flaws. No consensus is reached regarding the comparison to the Comet.
Participants note limitations in the ability to theoretically model flaws in composite materials and the importance of quality control in manufacturing processes. There is acknowledgment of the challenges in predicting long-term material behavior.
hammertime
Something like the Comet will never happen again.
Firstly because of increased technonlogy, we can run rigourous simulations looking at the behaviour of materials to make sure that its strong enough and won't fatigue.
Secondly because the modern society will simply not allow the 'suck it and see' attitude of the previous decades.
When CF airframes fly, they will be safe. As companies in this day and age just cannot afford to put forward something that is inherantly unsafe. This is not saying it will be invincible, there are always accidents and unforseen problems, but you arent going to get multiple failures.EDIT: Thirdly, there will never be a Comet style disaster again because of the Comet itsself... That plane single handedly killed british aviation for years.
I think the comparison is a stretch anyway - the comet failed due to fatigue, a problem that is difficult to predict in advance or test for. Composites don't exhibit fatigue, these failures are essentially design flaws that are found during early testing. They aren't good, but they will be gone by the time the plane goes into production.
Yes, it means there are some growing pains associated with composite planes (though they do already exist...), but that doesn't imply these will lead to in-flight failures.
hammertime said:
I just read http://www.newscientist.com/article...e-carbonfibre-planes-are-still-grounded.html" article and I had to ask something. Will the 787 have to go through a de Havilland Comet phase in order to be perfected? I mean, how do we know the composite airframes won't break apart after, say, six months, or a year, or five years?
Composite materials are just like any metallic material in that poor workmanship or unseen flaws will be possible locations for failures. Make no mistake that any material will fall into this scenario. There are a lot of things that are different that make it a completely different ball game then with the Comet. So much that, IMO, it is a stupid comparison. While the article is correct that simulations are not the end all be all because there is no way to theoretically model flaws or something that will degrade the material properties. That is what modern day quality control is for. We also have much more extensive test programs than during the Comet's time. The test bed fuselages will, most likely, get somewhere on the order of 10,000 simulated take offs and landings plus all of the flight testing done prior to certification. The Comet did not have testing like that until after they started crashing (they instituted water tank tests of cabin pressurizations).
I work with composites. I have nothing bad to say about them. There are so many different types of composite and composite process. The technology has come a long way. You have fiberglass kevlar composite and various blends of pure resin with many materials making up it's composition. With any process there are area's for mistake. Resins and epoxies are usually two parts. That should explain it. They also have to be agitated to remove air pockets. Last but not least while in the mold depending on the type there needs to be a nice even vaccum. Composites are an engineering design as well as any structure. They are harder to repair and make look good than standard sheetmetal or wood and steel tube designs. But there strength to weight ratio is uncomparable.
