Are rectangular block springs available in market?
Rectangular block springs, resembling mechanical keys, are not commonly available in the market, particularly in metal. The discussion highlights that while elastomers can achieve low stiffness values, their nonlinear stress-strain characteristics and the Poisson effect complicate their use as linear springs. Flat springs exist, but the design in question resembles a non-linear 'square rubber mount.' The conversation also references alternative spring designs, such as zigzag or magazine springs, and coil springs. Overall, the specific rectangular block spring design remains elusive in current applications.
k.udhay
TL;DR Summary
Spring design - Rectangular block springs
Dear all,
I am interested to know if there is any spring available which is just a rectangular block - Looks more like a mechanical key. Preferrably made of metal. The dimensions / numbers shown in the following image are indicative:
Pl. let me know if you have come across some applications similar to this. TIA.
Start with some basic calculations. The equation for column stiffness is ##k = AE/L##, where:
##k## = spring stiffness
##A## = cross sectional area
##E## = material modulus of elasticity
##L## = length (height) of the column
The only unknown is the material modulus, so solving for that results in a modulus of 20 MPa. That's four orders of magnitude less stiff than metals. Elastomers are available with modulus in that range, however there are two things to be aware of:
1) Elastomers have nonlinear stress-strain characteristics.
2) Even if the material has a linear stress-strain curve, the load deflection curve of a solid block is nonlinear. As the block is compressed, it squishes outward due to the Poisson effect, which increases the cross sectional area, which steepens the load deflection curve.
Flat springs are a thing, but your drawing looks more like a 'square rubber mount'. And those are (intentionally!) not linear.
A zigzag, or "magazine spring", made from a strip of flat steel.
Google images 'gun magazine springs'
Five coil springs, each 10 mm diameter, arranged in a row.
One thin walled, spring steel tube. 50 mm long by say 8 mm diameter.
leaf spring
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
