Are stress and pressure additive?
  • Thread starter Thread starter pyroknife
    Pressure Stress
Pressure and stress are defined as force per area, meaning if a uniform pressure of 1 atm is applied to a square rod, each sub-square of the rod's face experiences the same pressure. The discussion clarifies that if the force per area is consistent across the surface, the pressure remains uniform. Therefore, each section of the square face will experience the full 1 atm of pressure, not a fraction of it. The concept reinforces that pressure is additive in this context, as each point on the face experiences the same force per area. Overall, the pressure applied is uniformly distributed across the entire surface.
pyroknife
If we have some pressure/stress (say 1 atm) applied to an end of a square rod. Let's say this square face expression this pressure/stress is discretized into 4 squares of equal area. Each each sub-square experience 1 atm or 1/4 atm?
Pressure and stress are "force per area". If the force per area is the same everywhere, you have the same pressure or stress.
Oh, so each face would be experiencing 1 atm?
Each point will experience this pressure.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
