Are the axes of celestial objects parallel in a galaxy?
  • Level: High School
  • Thread starter Thread starter lw1990
    Axes Galaxy Parallel
3 replies · 2K views
lw1990
Speaking only of approximately spherical moons, planets, and stars (not asteroids), which rotate about their axis, are the axes all pointed approximately the same direction?
Is it true for moons and their parent planet?
Is it true for planets and their parent star (solar system)?
Is it true for stars and their galactic core?
Is it true for galaxy vs galaxy? Are they oriented in approximately the same axis?
Astronomy news on Phys.org
It's only approximately true for planets in a solar system and moons around planets - but there's plenty exceptions, even just in our solar system (most notably Uranus).
Otherwise it's random. (e.g., solar system's angular momentum axis is 'tilted' ~60 degrees off the plane of rotation of the Milky Way; similarly, there's no pattern in observed exo-systems)
The reason for approximate alignment in the first two cases is due to how bodies in a stellar system generally coalesce from one large molecular cloud spinning roughly in the same plane (due to the dynamics of collapsing gas clouds).
However, there's plenty of 'chances' for bodies formed this way to be later kicked out of this alignment. Collisions, orbital capture, orbital ejections - all act to randomise movement patterns.
On larger scales, the difference between the radius of rotation of a system (such as a galaxy, or a group of galaxies) as compared with the size of the area undergoing collapse to form a rotating object is too large to have any effect - in a similar way to how the Coriolis force can cause continent-spanning cyclones to rotate in a preferred direction depending on which hemisphere it occurs on, but it doesn't matter for the direction of water draining in your sink whether you're in Alaska or Australia (because local interactions dominate the evolution of the system).
have you ever looks at a deep sky image of many galaxies ? maybe not, as if you had, you wouldn't have asked that question :wink:
have a look at this pic and see what you think ...
at all sorts of anglesDave
Even within the solar system planets and other objects are not all orientated in similar ways.
Planets don't orbit the sun in exactly the same plane, only approximately so.
(and the orbital plane of Pluto, technically a dwarf planet nowadays, but still a substantial object, is way out compared to the main planet orbits.)
Polar orientation in relation to it's orbital plane differs widely between planets, Earth has tilt 23 degress and Uranus is an extreme case of 98 degrees, so its spinning sideways in relation to it's orbit.
Venus for some reason unknown rotates backwards as compared with other planets, (best guess is that it's even more extremely tilted than Uranus, effectively it has been turned upside down by past gravitational interactions.)
