Are there any decent dip package mixer ic's?
  • Thread starter Thread starter electricalcoolness
Decent DIP package mixer ICs are challenging to find, especially for simple applications like mixing two signals. The discussion clarifies that the focus is on mixers for radio work, specifically for frequency shifting. Mini-Circuits components are recommended as affordable and user-friendly options, available through Digikey. Participants seek simpler solutions suitable for breadboarding. Overall, the search for effective mixer ICs continues, highlighting the need for more accessible options in the market.
electricalcoolness
Are there any decent dip package mixer ic's? It's very difficult to find them. A simple mixer ic to mix 2 signals is all I need. I have seen 20 pin and 32+ pins. Anything out there that is simpler for the purpose of breadboarding?
More details please. A mixer as in an audio mixer that technically is a summing circuit or a mixer for radio work to generate new frequencies?
a mixer for radio work, to shift the same signal from one frequency to a new higher/lower frequency.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
