Are there purely diode, vacuum tubes?
  • Thread starter Thread starter Samson4
    Diode Vacuum
32 replies · 5K views · last reply
Samson4
I am looking for a very simple and specific vacuum tube. It doesn't have to be high power. I only need a plate that completely surrounds the cathode. No grids would be ideal. Anyone have a parts number or link for something similar to this?
Any diode such as 6AL5. Or maybe use a triode and connect the grid to anode. Then 6C4 or 6J5 would be suitable.
The 1B3GT Half-Wave Rectifier.
why this requirement ... considering most are such ?
well if it has a grid, it isn't a diode ! :wink: at minimum it's a triodeDave
a slightly rough way to do it, specially when there are many purpose built rectifiers out there :wink:
eg what Don has shown or here's another one
The 5U4G is a twin diode, use one or use both sections, take your pick :wink:
Dave
There are so many thermionic diodes to choose from. What is the application?
What is maximum reverse voltage and current? What is maximum forward current?
What frequency? and maximum capacitance between anode and cathode?
Dave
Now I have a question. How do anode voltages accelerate the emitted electrons if the plate surrounds the cathode? From my understanding, anything inside a conductor is uninfluenced by electric fields produced by the conductor. Do the plates truly surround the cathode?
In this pin layout, is M connected to ground?
This is from the 1b3gt tube dlgoff posted. Which pin; if any, is that metal cylinder wired to?
Am I the only one who finds the above quotes by the same person a bit odd?
What is odd about them?
Ummm, well in the first post it seems very important that the plate completely surrounds the cathode. In the other post I quoted it looks as if you were not even sure that tubes are actually constructed in that manner.
You can find all the answers to you questions in the RCA Tube Manual which you can download for free here. http://www.tubebooks.org/tubedata/RC30.pdf
Page five will give a general understand of vacuum tube diodes which are used as rectifiers.
Pretty much anyone who is experimenting with vacuum tubes will be using this manual. There will be more than a quick glance needed to understand this subject so you should expect to spend a good amount of time to get to understand what you read. As tube diodes are the least complex of the vacuum tubes, tube diodes will be not too hard too understand.
If you get stuck and need help, post here or PM me.
Cheers,
Billy
because of the big potential difference between the plate ( anode) and the filament (cathode)
totally different situation, doesn't relate to what is happening in a tubeDave
Probably. It is an external electrostatic screen or metal envelope. The plate or anode is, a.
The cylindrical plate structure is connected to a small top cap, well away and isolated from the pins, marked as p on the diagram. The black bump at the bottom of the diagram is a locating index on the base socket.The slender filament heated cathode is mounted on a central axis. The tubular anode plate surrounds the cathode, so the heat due to the accelerated electrons impacting the inside of the anode, can be radiated from the larger area of the tubular anode, outwards through the glass envelope.
Electric fields close to the cathode are critical to electron emission. For a triode, the control grid is placed very close to the cathode. The fields inside a capacitor or coaxial cable are all internal, similarly, the electric fields between the cathode and the inside of the tubular anode of a vacuum tube are self-screened which reduces the effects of external electric noise and so reduces interference with other nearby components and signals.
It was Lee DeForest who first investigated the triode amplifier. He discovered the effect when placing an antenna wire against the outside of the glass envelope of a thermionic diode that was being used as a wireless signal detector. It became his “Audion” in 1905.
It is lucky he was not using a tubular anode electrode, but something more resembling the separated anode “plate” still used in tube diagrams.
Thank you very much. This is exactly what I was looking for. Back to pin M in the layout. Does it stand to reason that I could turn on such a tube with a negative anode so that the electrons are attracted to the electrostatic screen? Then they would charge up the outer surface of the screen. Is this all reasonable?
if the plate is negative, then the electrons from the filament (cathode) will be repelled and the tube won't work
But this tube has an indirectly heated cathode. If I connect the cathode and the anode to the same negative potential, wouldn't all field lines will end on the screen connected to M?
not sure
I see absolutely no point in doing that ??
davenn said:
not sure
Quiet source of high voltage dc current with very simply circuitry. My electrostatic generator is very loud and flybacks need smoothing caps etc.
Samson4,
Any DC current coming from a tube diode will need filtering the same as would be the case with a silicon diode. All that comes out of a tube diode is pulsating DC. Connecting up a tube in a non standard way will most like destroy the tube and perhaps blow up in you face, set the house on fire...well...those are the minor issues that could come to pass...lol
Most tubes are high voltage devices, connected from the mains by a step up transformer designed to provide the correct voltage needed by the tube. Nothing about this is simple or cheep and has the real danger of getting you killed if you mess something up.
Please proceed with due caution if you go forward with this sort of stuff.
Cheers,
Billy
Quiet electrically or acoustically? Audio noise is usually generated by physical movement in magnetic components. Magnetostriction in a magnetic core or movement of windings on the core can often be a problem.
EHT flyback rectifiers are often made from chains of diodes with parallel resistors to equilibrate the reverse voltages across the many diodes. They are called “stick rectifiers”. The 1B3GT shown by dlgoff in post #3 was designed for use in EHT generators for B&W TV. It was replaced by semiconductor stick rectifiers.
Flyback diodes often need snubber networks made from series connected R and C. Snubbers restrict dv/dt and prevent voltage spikes that may damage semiconductor components or insulation.
Avoid the word “screen” as that refers to an internal grid close to the plate. The black circle, M, in the diagram is not strictly an electrode. It may be a metal sleeve inside and/or outside the vacuum envelope.
I think you are trying to use an inappropriate component do something you have not clearly specified. If you knew more about thermionic vacuum tubes you might see better ways of resolving your design requirements. It is highly unlikely that you will find neat low cost technical solutions by random assemblages of components you do not yet understand.
There is a wealth of knowledge available from the members of PF. If you specify your project and the problems you are having, you will receive several good suggestions from members, probably along with a better understanding of your design challenge. If you could ask the right question, you could answer it yourself. When you explain a project or problem to others, you will actually get to understand it better yourself. Give it a try here.
Quiet in the sense that when I power on my van de graaff, the room sounds like a textile factory. I am simply trying to replicate the mechanism of the van de graaff with a low power tube. A van de graaff deposits charges on the inside of a metal dome. I want to see if the same can be done with a simple thermionic tube.
This is the tube I believe to be of use.
Notice that the pin M is connected to the mesh surrounding both anodes and cathodes. The filament requires .1 amps at 19 volts. I plan to connect pins k and d to a negative potential to accelerate emitted electrons to the inside of the mesh. In this regard, I only want to see if the mesh will act like the dome of a van de graaff.
The total power input wouldn't exceed 2 watts. If I am using 19 volts and am able to achieve 100 volts at pin M, I'd consider that a big success.
Surface leakage across the glass base, or voltage breakdown between the pins will severely limit the voltages possible.
I agree, I'm only hoping for 100 volts. But, do you agree this could work? It will be fun to test anyway.
Connect d1 and d2 to m, ground k1 and k2, heat the filament. Some electrons will be emitted from the heated k, to reach d and so drive it negative. That will repel future electron migration and so limit the voltage.
How will you use 19V to pump charge onto the capacitance of the outer mesh ?
Remember that the filaments should be operated at a similar voltage to the k voltage.
What makes the vacuum tube better than a tin can ?
Baluncore said:
Connect d1 and d2 to m, ground k1 and k2, heat the filament. Some electrons will be emitted from the heated k, to reach d and so drive it negative. That will repel future electron migration and so limit the voltage. I was thinking to connect d1, d2, k1, k2 all to negative potential. This way, the electrons won't reach d, they'll accelerate towards the mesh. Any that move towards D, will accelerate away from d. D may have to be slightly higher than k to account for the kinetic energy of the emitted electrons.
The filament is indirectly heated by 19 volts at .1 amps. I will start by using -19 volts for k and D as well. I'll make adjustments if this is not enough but I think it's plenty.
The mesh could be charged to -100 volts but the electric field isn't going to effect the electrons inside it.
What do you mean? A tin can isn't in a highly exhausted glass tube. I can't expect the filament to survive for long in the atmosphere. If this works, I'll see how much a custom tube will run me. With some spherical components and a heavy duty filament, I'd like to see the kinds of voltages achievable with a couple 9 volt batteries.
The internal construction will have the two cathodes, each inside an anode tube, both surrounded by the mesh, m. The filament will be an oxide insulated tape in the form of an inverted 'W' that internally heats the thin cathode tubes. It passes up and then down each cathode tube.
I see little point in tying k1k2 and d1d2 as the electron emission from the heated k1k2 is then short circuited to d1d2. If you make k1k2d1d2 = –19V then will the filament terminals f & f will be connected to 19V and presumably 0V ?
Any electrons that reach the mesh will drive the mesh voltage down until it repels as many electrons as it attracts.
Charged relative to what? The electric field inside the mesh is inside it relative to the bundled electrodes. The outside of the mesh is insulated by the cold vacuum and glass envelope from the outside world.
Any voltage that you apply between m and the k1k2d1d2 bundle to accelerate or attract electrons will clamp the voltage on m relative to the bundle.
Please draw a circuit diagram to show what you have not specified. At the moment it looks like you are trying to lift yourself by your own conceptual bootlaces.
Are you sure that each cathode is inside an anode tube? If this is true then I can understand why I'm not making sense. I know the pin layouts are simplifications but this is a big let down. Although, I still don't understand how an inner electrode can be influenced by a concentric outer cylinder.
How will the mesh voltage repel electrons? If it's purpose is electric shielding, why wouldn't it behave like a faraday cage?
Charged relative to my multimeter. I understand that k1k2d1d2 would have field lines all extending to the mesh M if k wasn't surrounded by d. But: since you say it is, then this is all wrong.
What do you mean by this?
Yes. It is the only sensible rigid construction that is capable of dissipating the anode heat. I have taken many dead vacuum tubes apart to study the construction and the internal failure mechanism that stopped them. The concentric construction seems to be universal.
The gap between the two is a capacitor. The environment of the inner cylinder is the outer cylinder. The outer cylinder is open at the ends so charge can pass between the inside and outside surfaces.
It's purpose may have been shielding, but you are using it as a cylindrical plate electrode.
A multimeter has two terminals. Any voltage is the difference in voltage measured between two points. Voltage is meaningless if you do not identify the reference.
Draw the circuit diagram. Show the connections between all the participating electrodes and show both sides of the DC supply. Only then can we understand what you are considering. You might discover that what you are contemplating is actually impossible.
I now see that it's the dual diode setup that is impossible for this use. The anode does have to attract or repel electrons just as you say. But maybe, a tube with a grid can be coerced into working in the manner I need. I need a tube similar to this, just a triode with a concentric plate.
Perhaps a grounded grid and a cathode negative enough in relation to the grid to accelerate the electrons past the grid.
I will research more of these tube designs and come up with a circuit.
