Automotive Are Twin Turbos on a 4 Cylinder Engine Worth it for High Performance?
  • Thread starter Thread starter KidWonder
    Cylinder Engine
Twin turbos on a four-cylinder engine may not be practical, as a single turbo can provide sufficient boost and quicker spool times with less modification needed. The complexity of twin turbo systems often outweighs their benefits for small engines, especially given advancements in single turbo technology. Modern single turbos, such as multi-vane or variable-nozzle designs, offer improved performance across a wider range of conditions, making them more efficient than twin setups. While some enthusiasts have successfully used twin turbos on four-cylinders, it is generally considered an odd choice for high-performance applications. Overall, a well-chosen single turbo is typically more effective for enhancing a four-cylinder engine's performance.
KidWonder
Hey Guys, I'm fairly new to this forum.
I would just like to know is their a way to allow for a four cylinder engine to produce for more engine gas to spin 2 turbos. As I researched on forced induction, I've found that Twin turbos on a four cylinder might be one turbo too many, though I imagine the spin-up (lag free) benefits of two teensy, weensy turbos might be there as on a bigger motor. I'm in High School, and planning on studying Mechanical Engineering at Ohio State, then start a car company(not likely).
Thanks Guys
God Bless
welcome fellow Buckeye
I do not know but would recommend you research the Offenhauser 4 cylinder engine that was refined to the ultimate 4 cylinder thru Indy years as a start.
rm
From Subaru
http://memimage.cardomain.com/ride_images/3/2909/81/32270040002_large.jpg
Look up what people do to their road/rally cars from Subaru and Mitsubishi. There are countless sites and threads from people who have twin blown their 4 bangers. However, why would you want to? On a small 4 banger, you certainly won't need that much boost and you'll have to figure out other stuff before you can drive it. Simply slapping on a couple turbos doesn't make a fast car. A good GT40 turbo will provide plenty of air to a 4 cylinder. Single turbos also spool quicker and require a lot less engine modification inside the small engine bay of a 4 cyl. car.
Twin turbo systems would be classed as an odd choice for a performance small 4 cylinder engine used for automotive use. Twin turbos are (in general) phasing out due to modern turbine development of multi-vane or variable-nozzle turbines which allow for a single turbine to operate over a far wider range of exhaust gas flow rate than was possible twenty years ago, therefore applications which would have been twin turbo to achieve a usable power-band all round have been phased out to multi-vane or variable nozzle single turbocharger applications which offer inherently less frictional losses and complexity. That being said, twin turbochargers are still used on some flat-plane V8's and Boxer configurations as each bank of cylinders opperates a separate exhaust system.
I don't know if this irony or not.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
