Are virtual particles really there?
250 replies · 55K views
Of course if you accept the fact that all detected particles must be virtual particles by definition, then you end up with having only virtual particles and no real particles in your theory. That's correct.
But - what do we learn from that? If we have "virtual particles" only, why not call them "particles" w/o the "virtual"?
I think this does not help
So you finally agree that we should not differentiate between "virtual" and "real" particles?
Tom, this exactly is the point!
Please check my post #25:
I think the existence of virtual particles is more a question about "existence" than about "virtual particles". Let me explain:
First of all virtual particles "exist" as they are (as a mathematical tool) able to describe a real process accessable experimentally.
They do not exist in the same sense as the "real" out-states exist b/c an out-state is always "one single particle" whereas a virtual particle is an integral over a "collection of particles" described by propagators. So there is a huge difference.
Last but not least there is a ontological paradox. First of all virtual particles do not exist as no experimentalists cares about them; what is prepared is an in-state, what is detected is an out-state, so virtual particles are not accessable experimentally. But as soon as a particle is detected it interacts with the measuring device; this interaction is described via a Feynman diagram and in this Feynman diagram the out-state becomes an internal line, a virtual particle so to speak. If existence is related to observation everything that exists can only be described by virtual particles b/c out-states = real particles do not interact and are therefore never observed by construction!
So it seems that I already came to this conclusion some time ago :-)
The key issue is: if you restrict yourself to "virtual particles" in the textbook sense you are far away from modern physics. If you instead insist on virtual particles being real you run into a paradox or a tautology. If you try to base your understanding of QFT on virtual particles you may run into the problem to mix up "perturbation expansion" with "definition of quantum field theory".
Virtual particles don't help us to understand QFT; they confuse us! Once we have understood QFT and once we did some perturbative calculations we may safely talk about them (like the Nobel prize winners you have cited). But from an educational perspective it's b..llsh..
Btw.: you seem to see the PI formalism as more fundamental than the canonical approach. Let me say that it's the other way round: the PI approach was originally derived by Feynman using the canonical approach and there are many physicists today rating the canonical approach as the more fundamental one.
tom.stoer said:
It has nothing to do with renormalization, but with the definition of the perturbation series itself...
Thanks, that's clear :)
I have not followed the whole threat, so forgive me for barging in here, but...
kexue said:
No Tom, this is exactly the point! This is the basic idea of QFT. It demands virtual particles to work, they are essential to quantum field theory.
And as I said, in order to do non-perturbative quantum field theory you have to use the path integral approach, where you compute not with quantized fields, but with classical fields, were virtual particles per definition do not appear. But to do non-perturbative calculations you have to integrate over all paths, even overvirtual ones.
So asking for non-perturbative calculation with virtual particles, does not make sense. What I can show though, is that every non-pertubative calculation which has to be carried out by path integral approach, implies, of course, integrating over virtual paths. Per definition.
Are you claiming that non-perturbative approaches can only be carried out using a path integral approach? Because that statement is simply wrong.
Take for instance Conformal Field Theory in two dimensions. They are an example of integrable quantum field theories: quantum field theories which contain an infinite number of symmetries. The symmetries give rise to an infinite number of constraints -- the Ward identities (a special class of these are known as Knizhnik-Zamolodchikov equations). It's the quantum version of a Noether current.
The constraints basically come down to differential equations which are satisfied by the correlation functions. Let me state that differently:
Every correlator satisfies a linear differential equation (with respect to the coordinates of the fields in the correlator). And by solving the differential equation you obtain an expression for the correlator.
Everything is exact, everything is non-peturbative. It's an interacting theory, and it's strong coupling. But most of all: there is absolutely no reference to intermediate states which are summed over. There are _no_ virtual particles.
Kexue, I still don't quite understand your point of view, first I thought you were confusingly mixing real and virtual particles but then you start bringing up a "field centered" view that seems to make distinctions between real and virtual particles useless, and this could be interesting, I always thought QFT was deriving towards a too "particle centered-high energies" perspective that seems to be a dead alley (well, let's wait til we have any surprise from the LHC), but then ,do you suggest that virtual particles are the quanta of some field?
I think kexue just wants to know whether these "mathematical artifacts" are really popping in and out of existence, regardless of the arguments for and against mathematical rigour
eg: It's confirmed: Matter is merely vacuum fluctuations
I mean, we don't have to be able to observe them, I guess the point is that there should be a correct and simplest way to describe nature mathematically, and we should then be able to run a simulation of that mathematical model on a computer and have a "look" at the scale of protons and see what it looks like.
kexue said:
I thought about posting more quotes, but then, what for?
so that we can read them :smile:
kexue said:
Only if a photon lives forever, moves forever, it would be on-shell. Every photon that gets created and absorbed is not.
do you have a reference for that (and not an email)? :confused:
Kaku and especially Maggiore claim in their textbooks that non-pertubative calculations do not work in canonical quantization, since an exponential of an operator is defined by its Taylor expansion.
The rest I wrote was admittely wild speculation. All I know is, that when we got a path integral, either in qm or in qft, we have to integrate over all possible paths. In qm that would be paths that a classical particle never could take, paths that do not obey special relativity, i.e. faster than light, backwards in time, whatever. similar wild paths are taken when we integrate over field configurations. I called them freely virtual paths.
My reasoning was (proabably naive and wrong) that these "crazy" paths correspond in some sense to the virtual particles in the canonical quantization calculations.
I subscribe to what I arrogantly call the Feynman way of thinking, as described by the Susskind quote or what I was trying to convey more clumsy in post 111 and what I think is an important message to understand, that there is no qualitative difference between virtual and real particles, particles can be more or less "off-shell", but are never actually exactly on-shell.
Basically, this what I like to emphasize. Tom and others do not find that helpful, though I understand they admit it is a legal view.
And no, I do not think of virtual particles as little billard balls or interpret single Feynman graphs naively as a single physical processes.
And of course Tom's objections (first and foremost: where are the virtual particles in non-pertubartive calculations?!) are well taken, and to be honest I'm not in the position to argue with him. For that I know way to little quantum field theory.
kexue, either you are misinterpreting something or this is simply wrong (sorry, Prof. Kaku). In canonical quantization there is at the very beginning no need to define an exponential of an operator. You just need the Hamiltonian H (which has a well defined exponential provided that H itself is well-defined). Later you may want to define the time evolution operator U, S- or T-matrix - and for that you need an exponential of iHt.
But it is this exactly this way you derive a path integral and for that we still do not know how to proof its existence. So the construction of H is fundamental to QFT, even for the PI; you can't bypass H or T in order to derive the PI.
[You may check textbooks where they use some thing they call H, sandwich it between some states and derive the PI; in a very last step they calculate the Gaussian integral to go from the Hamiltonian to the Lagrangian PI; in order to do that you need some H - and you need H to have a rather specific form: it has to be quadratic in the momenta; none of these steps can be justified mathematically w/o having first constructed H; what they do instead is to write down Z[J] and call it the PI; so I am sorry - I don't trust textbooks here as they omit well-known obstacles; what about Weinberg? he seems to be rather serious about those topics, but I haven't studied his books, unfortunately]
Note: regardless what we believe about H or Z, up to now no perturbation expansion has been used.
I think you got the main idea; the confusion is due to the fact that you called these non-classical paths "virtual".
Assume for a moment that you have a way to define this procedutre rigorously; I think lattice gauge theory is a rather good example. Then your PI will collect contributions from non-classical paths. It that sense you are right. But then you have to make your last step drop the distinction between real and virtual. In lattice gauge theory all quarks and gluons "are" in a sense "virtual"; not even the bound state (e.g. the proton) is "real". But note: calling these "particles" "virtual" is misleading as the term is reserved for perturbation theory - but we didn't use perturbation theory here.
kexue said:
... what I was trying to convey more clumsy in post 111 and what I think is an important message to understand, that there is no qualitative difference between virtual and real particles, particles can be more or less "off-shell", but are never actually exactly on-shell.
As said I tend to agree here.
I think it was a long a thorny detour, but it was hopefulyl not in vain :-)
I like this view, but I think the universe itself is "on-shell", but no subsystem within it is.
now we have a sticky thread with 131 posts; that was of course not the intention for a sticky thread :-)
No, the point is that you're reading the right books and naming the right authors, but you don't understand the material. You know, it's easier to just take the time to learn and share ideas rather than try to convince a 'room' full of people that black is white.
As stickies for virtual particles go, there are MUCH better threads to sticky in which there isn't some endless battle for one fellow's ego and worldview.
I don't quite get this 'slightly off-shell' part.
To me, it sounds more natural to say that a real particle state contains small off-shell components. I guess it is a totally different situation compared to the case where a virtual particle becomes almost on-shell (which sounds more or less similar to slightly off-shell), which means that it is more of an actual transition rather than a perturbative correction.
Please do interpretet too much here; these are only words, interpretations, ...
On-shell, off-shell real and virtual have a precise meaning in perturbation theory (and I think they are nearly meaningless in the non-perturbative regime). A particle with rest mass m is on-shell if it's 4-momentum p satisifies p² = m², otherwise it's off-shell. A real particle in a Feynman diagram (an in- or an out-state) is always on-shell, a virtual particle that is exchanged can be off-shell; in loops, where momentum-integrals survive the 4-momentum conservation constraint at the vertices, particles can be arbitrarily off-shell as one integrates over 4-momentum.
The propagator is usually something like 1/(p²-m²) which means that virtual particles must not be on-shell as that would mean they would always sit at the pole; therefore being off-shell and being virtual is the same.
You could e.g. use the naive electron-positron scattering at tree level to calculate the mass of the exchanged photon.
Right. Still, as is pointed out, all the particles we detect are not exactly in asymptotic states . They should have some amount of perturbative correction(off-shell components), in principle, although we don't really care about it when calculating the scattering matrix.
My point was just that calling this simply 'slightly off-shell' sounds misleading.
If I understand you correctly you are referring to the fact that strictly speaking one cannot detect asymptotic plane wave states as they do (by definition) not ineract with a detector. I am not sure if one should try to fix this via "being slightly off-shell" rather than referring to the "measurement problem".
This would lead to a discussion "what are particles?" instead of our the discussion "what are virtual particles?"
Maybe I wasn't specific enough on expressing what I mean. Let me elaborate.
From what I know, in an asymptotic state, particles are assumed to be very far away from one another so that they don't interact. However, as this is only an idealization, the state that is actually detected should be (asymptotic state) + (correction terms due to inter-particle interaction). These correction terms should be off-shell.
Something like that can be done, but it's not that particles are off-shell. I know the method of so-called distorted waves, which can e.g. be used to calculated scattering states, phase shifts, nuclean mass corrections in soliton models (Skyrme model and related models). The idea is not to use plane wave states but exact solutions of the full problem with the soliton included. These solutions are then used to construct the appropriate operators for the canonical quantization, especially H and T and to do the renormalization.
The difference to your ideas is that interaction taken into account is not due to the detector, so strictly speaking the asymptotic states are on-shell again.
My point is that the detector is never placed at infinity, so that the "out-state" we measure is not exactly the asymptotic out-state, in which particles don't interact at all since they are infinitely far away. The difference between the actual and ideal out-states are basically perturbative corrections due to the interaction, and I guess it is OK to call just that part (however small that is) virtual or off-shell? However, as I've said, I disagree with calling the whole thing (the out-state we measure) "slightly off-shell".
I see what you mean, but I don't think you can use this to calculate anything.
Looking at Feynman diagrams you either have internal lines or external lines. The internal lines (virtual particles) are never detected, the external lines which correspond to real particles (which are detected) cannot be modified. In order to do that (to introduce the interaction with the detector) you would have to convert the external line into an internal line.
The formalism simply does not allow external lines to be "slightly off-shell". That's why I say that I understand the problem (it is a problem in the sense that our idea of reality and the strict interpretation of the formalism seem to be in conflict), but I don't see how to solve it in the given formalism. My response regarding the "measurement problem" is not satisfactory, but I don't see a way out.
I agree. This is just a conceptual matter. I was just trying to understand what kexue means by "slightly off-shell" and what Lenny Susskind means by saying that "every particle is virtual".
Damn, this thread is really sticky!
I have a question (it is really a question, I'm not trying to make a point in any way).
Could you tell me what "really there" means, and how it differs from "only tools".
thanks
(Hope that is not a philosophical question.)
thanks
Of course that's a philosophical question, but it's a practical one in physics I suppose. Only a tool means that it doesn't exist in nature; in other words it's a concept used to bride a gap. For something to be, "really there" is... self-explanatory, or to put it in similar terms: "really there" applies to a gravity, "maybe there, maybe pure theory" applies to gravitons, and "never believed to exist, just a tool", would be virtual particles.
Is society "really there" or is "only a tool" in our understanding of what people do?
Are people "really there" or are they "only a tool" in our understanding of the behavior of complicated piles of water, proteins, fats, etc?
I would say that society is an emergent property of a given number of cohabiting humans.
I would say that people are really there, and are primarily constituted of water, proteins, and fats.
I would distinguish these from virtual particles by noting that however you word it, there is the virtual particle tool... and that's it. There isn't a "bag of mostly water" or more abstract concept to cling to... they're just a way of solving a problem. SOMETHING is presumably occurring, but what it emerges from or constitutes it is still a mystery and has no relation to the concept of virtual particles.
tom.stoer said:
please refer to my post #28
That, or we could all just burn some patchouli, smoke some weed and say, "duuuuude", in the manner questions like the two posited deserve...
I like the quote. (provided by Tom!)
Nismaratwork, what is an essential object then to you?
kexue, personally I think that ontological questions are rather interesting - but unfortunately neither physics nor physicians are good in explaining them; that's why I think we should prevent this thread from a "philosophical turn".
