Area Calculations to find Jc energy Parmeter (simple maths)
The discussion revolves around calculating the area of a load-displacement plot to determine the Jc energy parameter. The original calculation led to a negative value for the blue shaded region, indicating an error in the area calculations. A participant pointed out that the largest triangle was misidentified, suggesting a different approach using a base of 10 and height of 1.8. After revising the method by splitting the diagram into four triangles and one rectangle, the user successfully obtained a positive area. The problem was resolved with the corrected calculations, leading to the desired outcome.
50Cent
I have been given the following load-displacement plots for the same specimin with two different crack lengths. The lines are identical up to a load od 750N
i need to calculate the area of the blue shaded region to obtain a value of Jc using a separate equation.
Area of triangle = 0.5(b)(h)
Area of rectangle = (b)(h)
I found the area of the largest triangle (tip at 1750)
Total Area = (0.5)(0.003)(1750)=2.625
Then split the lower half of the plot into 3 sections labeled 1,2&3. And calculated the areas
Area 1=(0.5)(0.0012)(750)=0.45
Area 2=(0.003-0.0012)(750)=1.35
Area 3=(0.5)(0.003-0.0012)(1740-750)=0.891
So Total Area - Area 1 -Area 2 - Area 3 = the blue shaded region
However i get a negative value,
Blue Shaded region = 2.625-0.45-1.35-0891 = -0.066
Just by looking at the picture, it shouldn't be a negative value, I can't see the problem in my method. Can any1 see what I am doing wrong?
Any Help is appreciated
Thanks
Part of your problem is I think the "largest triangle" is not actually a triangle. If (1.2,750) is a point on the line, then (3,a) yields 750 x 2.5 for a, which is not 1750. Can't you just use 10 as the base and 1.8 as the height for a triangle?
Hi,
I tried it again by doing what you suggested and splitting the diagram further into 4 triangles and 1 rectangle. I got a positive area and solved the question :D
Thanks for your help!
