Area of quadrilateral knowing 3 sides and 2 angles
  • Thread starter Thread starter j9mom
    Angles Area
To find the area of a quadrilateral with three known sides and two angles, one can use the properties of triangles and trapezoids. The discussion suggests drawing a diagram to visualize the shape, which can help in applying the area formulas for both the trapezoid and the triangle formed within the quadrilateral. The angles provided, along with the known side lengths, can assist in calculating the remaining angles using trigonometric functions. This approach allows for a systematic way to solve the problem by breaking it down into simpler components. Overall, visual representation and strategic application of geometry principles are key to finding the solution.
j9mom
Is there an equation in which I can find the area of a quadrilateral when I know the length of three of the sides and 2 of the angles? Also I really need to find the measurement of the other two angles.
I know the cos and sin formulas of triangles, and may be I can use that but I do not know how to start
The lengths I know are 15, 12 & 2 and the angles I know are 120 degrees between the 12 and 2 and 120 degrees between the 15 and the side I don't know.
I really need a nudge to start.. this is a small portion of a much bigger problem.
Draw a picture. Find the area of the bottom trapezoid and top triangle then add them.
OK, let me try that. I never thought of a trapezoid. Thanks.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
