I Can the same argument be used for both radians and degrees in the sine function?
  • I
  • Thread starter Thread starter fog37
    Argument
The sine function can accept inputs in both radians and degrees, but it is crucial to understand that the mathematical definition primarily uses radians. When using degrees, a conversion to radians is necessary for accurate calculations, as many programming languages and calculators default to radians. This conversion is often overlooked, leading to significant errors in computations. While the sine function produces outputs between -1 and 1 regardless of the input unit, the interpretation of the angle must be consistent to avoid mistakes. Understanding these nuances is essential for clear communication and accurate problem-solving in mathematics and engineering contexts.
fog37
TL;DR Summary
angle argument of a sine function
Hello,
I understand that the sine function take an argument as an input and produced an output which is a real number between 1 and -1. My question is about the argument. I know it can be in either radians or degrees which are different units to measure angle. An angle is the portion of the plane between two lines that meet at a vertex.
For example, let's consider a function that takes the length of the side as input and calculates the perimeter of a square: ##f(x)=4x##. The output is correct regardless of the input being in feet, meter, inches, etc. However, the numerical output is different depending on the unit of ##x##.
What about in the case of the function ##f(x)=sin(x)## or ##f(x)=3sin(4x+30^\circ)##? If ##x## is in radians or degrees, the answer is the same...How is that possible? I am trying to explain this concept to a friend but I am convincing and clear.
thanks!
Mathematics news on Phys.org
If those are interpreted by a human, he can make the appropriate adjustment in his interpretation. If they are in computer code, then the computer language will insist that the input to sin() is in radians. If you want to use degrees, you will need to make the appropriate conversion of units: sin( degToRad * x_degrees), where degToRad = ##\pi / 180 = 0.0174532925199433##.
It is very common to see a mistake in computer programs where the input to the sin() function is degrees without the conversion. The effects are serious. A tiny change in degrees is interpreted as a change in radians, which is much larger.
I'm not a mathematician, but I think the sine function works on radians, a dimensionless number (radian measure is a ratio). Your calculator uses the Taylor series (or some other faster series:
sin(x) = x+ x^3/3! - x^5/5! ...
If your calculator takes the argument in degrees, it first converts to radians (rad = pi * (deg/180)).
EDIT: basically, what @FactChecker just said.
fog37 said:
TL;DR Summary: angle argument of a sine function
Hello,
thanks!
The sine function in general mathematics is almost always has an argument in radians. That said, using degrees is quite common in engineering and mechanics problems.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
