MHB [ASK] Equation of a Circle in the First Quadrant
  • Thread starter Thread starter Monoxdifly
    Circle
The center of circle L is located in the first quadrant on the line y = 2x, with the circle touching the Y-axis at (0, 6). The coordinates of the center can be determined as (3, 6) since the y-coordinate is derived from the tangential relationship to the Y-axis. The equation of the circle can be formulated as (x - 3)² + (y - 6)² = 3², leading to the simplified equation x² + y² - 6x - 12y + 36 = 0. The discussion also clarifies the correct use of "lies" versus "lays" in this context. The final equation represents the circle's properties accurately based on the given conditions.
Monoxdifly
MHB
The center of circle L is located in the first quadrant and lays on the line y = 2x. If the circle L touches the Y-axis at (0,6), the equation of circle L is ...
a. $$x^2+y^2-3x-6y=0$$
b. $$x^2+y^2-12x-6y=0$$
c. $$x^2+y^2+6x+12y-108=0$$
d. $$x^2+y^2+12x+6y-72=0$$
e. $$x^2+y^2-6x-12y+36=0$$
Since the center (a, b) lays in the line y = 2x then b = 2a.
$$(x-a)^2+(y-b)^2=r^2$$
$$(0-a)^2+(6-b)^2=r^2$$
$$(-a)^2+(6-2a)^2=r^2$$
$$a^2+36-24a+4a^2=r^2$$
$$5a^2-24a+36=r^2$$
What should I do after this?
Mathematics news on Phys.org
circle center at $(x,2x)$
circle tangent to the y-axis at $(0,6) \implies x=3$
$(x-3)^2+(y-6)^2 = 3^2$
$x^2-6x+9+y^2-12y+36 =9$
How did you get x = 3 from (0, 6)?
The fact that the y-axis is tangent to the circle at (0, 6) means that the line y= 6 is a radius so the y coordinate of the center of the circle is 6. And since the center is at (x, 2x), y= 2x= 6 so x= 3.
(And the center of the circle "lies on the line y= 2x", not "lays".)
Well, I admit I kinda suck at English. I usually use "lies" as "deceives" and "lays" as "is located". Thanks for the help, anyway. Your explanation is easy to understand.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
