MHB [ASK] How much velocity is needed for the rock to be able to hit that bird?
To determine the velocity needed for a rock shot from a slingshot at a 37-degree angle to hit a bird at coordinates (50, 8) m, the equations of motion were applied. After substituting known variables, the time of flight was calculated to be approximately 2.43 seconds. This led to the equation for horizontal distance, resulting in a required initial velocity of about 25.8 m/s. The discussion highlights the challenge of working with irrational numbers in calculations. The complexity arises from the need to accurately approximate these values in the context of projectile motion.
Monoxdifly
MHB
A bird is located at the (50, 8 ) m coordinate. A boy shot a rock at it using a slingshot with the elevation angle $$37^{\circ}$$. How much velocity is needed for the rock to be able to hit that bird?
I substituted all known variables (including the gravity acceleration $$10m/s^2$$, with $$\sin37^{\circ}=\frac{3}{5}$$ and $$\cos37^{\circ}=\frac{4}{5}$$) to $$x=v_0\cos\alpha t$$ and $$y=v_0\sin\alpha t-\frac{1}{2}gt^2$$. Substituting the $$v_0$$ I got from both equations resulted in $$\frac{125}{2t}=\frac{40+25t^2}{3t}$$ and I got $$t^2=5,9$$. Am I right? Because if it is indeed the right value of t, everything will be complicated from there.
Mathematics news on Phys.org
Yes, that is correct and then t= \sqrt{5.9}= 2.43 (to two decimal places). But why do things "get complicated"? You have x= 50= v_0 cos(37)(2.43)= 1.94 v_0. v_0= 50/1.94= 25.8 m/s.
Probably just because I'm not used to the approximation of irrational numbers.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
