Asking about the Vcc of some integrated circuits
15 replies · 4K views
hagopbul
Hello:
I have to ask some question , did anyone know any integrated circuits that have voltage Vcc of few kilo volts what was the catagoeries of that circuits ?
And do they different from high current integrated circuits ?
Where to read about it ?
Best hope
hagopbul said:
Hello:
Best hope
Generally, no. There are limits to the voltages which a solid state device like an integrated circuit can withstand without breaking down. Most integrated circuits are limited to a few 10's of volts. With special design, it is possible to engineer the breakdown voltage to be a few hundred volts, and these types of ICs are commercially available. I am not aware of any ICs with breakdown voltages of 1 kilovolt or higher. For these types of applications, typically we use devices other than semiconductors, such as vacuum tubes.
I remember one time I saw a microcontroller that work on 220 volts it look like I am mistaken
No, I don't think you are mistaken. As I said, a few hundred volts is possible. I have seen power ICs that go up to 600 volts. I've never seen anything above 1 kV.
my guess is it was an X10 type device that commnicates over the power line to control appliances and lights...
they drop line voltage down to something that's useable
https://digilander.libero.it/cvolpato/elettronica/download/00236a.pdf
old jim
hagopbul said:
Hello:
Best hope
From few few kilovolts switches, ICs are used to drive relays. Relays capable to handle even megavolt-range lines. Directly using such high voltage for IC is not practical (most silicon circuits are limited to 1200V), therefore HV mains are connected to ICs power supply typically through step-down transformer. Variations of IC isolation (resitive divider, ballast capacitor, floating ICs, opto-couplers, opto-thyristors) do exist depending on application.
how would you insulate the pins of an IC against kilovolts ? They're only a few thousandths of an inch apart.
For that you may use thin film coating ,but that other subject entirely not related to this question
?? This one ?
well. it was you who brought it up.
I'm pretty sure that there is no such thing. Vcc usually defined as the (positive) supply voltage: in this context, it would be what keeps the integrated circuit working. To use such high voltage to power an IC - insane.
If you are asking about integrated circuits which are intended to handle high voltages - that's a different story. But such circuits usually has the actual Vcc below a dozen volts. Sometimes it's produced by an internal regulator, but even so...
Best example is the good old TTL nixie drivers I think. TTL circuits (Vcc around 5V) handling 'high' voltage.
Other example would be some power amplifiers, with separate power input for the last stage, but low voltage Vcc for the actual IC part.
You might be able to find something around hybrid circuits. But that's not really IC, as I take it.
hagopbul said:
Forgive me for that
Forgive my snap at you.
we all have slips of the tongue from time to time.
old jim
hagopbul said:
Hello:
Best hope
Is this question asked in order to find a 'chip' that can perform a particular function or is it a general interest question (the sort of question that comes up in typical pub conversations)?
There can be no definitive answer to this question because we would need to define what the OP means by the term "Integrated Circuit". It is possible to encapsulate a circuit into one package and inside the (specialist) package there could be a very high voltage (or current) unit - higher than any included monolithic chip could stand. I think the term for this would be Hybrid Integrated Circuit.
