Assuming [Cl‑]o = 150 mM and [Cl‑]i = 8 mM.
  • Thread starter Thread starter djflush
The discussion revolves around calculating the Nernst equation for chloride ions, with extracellular concentration [Cl‑]o at 150 mM and intracellular concentration [Cl‑]i at 8 mM. The user initially calculated a value of -65 mV but expressed confusion about the negative result, questioning if it should be positive since z is considered as 1. Other participants pointed out errors in the user's calculation process, specifically in the third and eleventh steps. They emphasized the need for a clearer explanation of the problem to provide effective assistance. Overall, the conversation highlights the complexities of applying the Nernst equation for ions with negative charges.
djflush
assuming [Cl‑]o = 150 mM and [Cl‑]i = 8 mM. because Cl‑ ions are negatively charged, there’s a change to the Nernst equation - z is now ‑1
i got -65mv but this doesn't look right am where am i going wrong suddnt it be a plus value
as z is 1
You're making mistakes in the third and eleventh steps.
Cryptic?
So is your description of your problem. You need to be a lot more thorough to get any meaningful help.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
