Astronaut traveling what effects would she feel?
  • Thread starter Thread starter goWlfpack
    Astronaut Effects
An astronaut traveling at 0.5c would experience several effects related to special relativity. While her heart rate and dimensions would remain unchanged from her perspective, she would feel heavier and find it harder to breathe due to the pressure and forces acting on her. The discussion highlights that time intervals and length contraction are relative, meaning they do not affect the astronaut directly while she is in motion. The importance of considering these factors when designing equipment for space travel, such as a bed, is also noted. Overall, the astronaut's experience would be influenced by the conditions of her environment rather than her own physiological changes.
goWlfpack
astronaut traveling.. what effects would she feel??
An astronaut is traveling in a rocket in outer space in a straight line at a constant speed of 0.5c. Which of the following effects would she experience?
Her heart rate would change.
She would feel heavier.
She would find it harder to breathe.
Some of her dimensions would be shorter.
None of these effects would occur.
i thought all of them (except the last would occur) i know that she would feel heavier and i know that it would be harder to breath. I am pretty sure the heart rate would change because of the speed, and the dimensions would be shorter because she is traveling so fast right?? or would her dimensions be the same b/c her frame of reference is moving that fast too??
In special relativity, what clocks and rules are affected by time dilatation and length contraction, respectively?
well with length contraction, if the observer is moving, objects appear shorter if they are stationary, and a time interval to an observer in motion will appear longer then an observer at rest. So the heart rate would seem slower?? but would it actually change?
Well, the point is, that time intervals of one observer A will appear longer for another observer B (in relative motion) but not for A himself. Similarly for length contraction.
So, for example, would she have to had taken length contraction into account while building the bed on board her spaceship before departure?
oh ok, so b/c in this case the observer is moving the time intervals will not seem any different? so heart rate stays the same. The dimensions should as well then, b/c the area she is in is moving at the same speed as her.
she would feel heavier though and find it harder to breathe b/c of the pressure and the force of gravity working against her right?
Do you find it hard to breathe while traveling at 30 km/s through space?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
