What is the behavior of an electron in an asymmetric potential well?
In summary, the potential provides a way to create a ground state that is peaked over the deeper well.
bcrowell
Staff Emeritus
Insights Author
431
Consider a nonrelativistic electron in one dimension, with the potential
[itex]
V(x)=\left\{
\begin{matrix}
\infty, \quad x<-a \\
-4V_0, \quad -a<x<0 \\
-V_0, \quad 0<x<a \\
\infty, \quad x>a
\end{matrix}
\right.
[/itex]
I use this as an example when I teach the Schrodinger equation in a freshman survey course. Say you're looking for a solution with an energy E=0. The momentum in the left half of the well is double what it is on the right, so the wavelength on the left is half of what it is on the right. To match the two pieces of the wavefunction without a kink, you need to have double the amplitude on the right, which corresponds to four times the probability, [itex]P_R/P_L=4[/itex].
Classically, the particle moves twice as fast on the left, so it spends half as much time there. If you peek at it at some randomly chosen moment, you find [itex]P_R/P_L=2[/itex].
Comparing these two results, you get qualitative but not quantitative agreement, and this seems to violate the correspondence principle. But in the classical limit, you can't really put the electron in a pure energy state. It's in an incoherent superposition of some large number of states with [itex]E\approx 0[/itex]. The incoherent superposition gives [itex]P_R/P_L=2[/itex], in agreement with the correspondence principle.
This would seem to be a natural model of an asymmetric diatomic molecule, but my intuition tells me that the electron would "want" to spend more time in the deeper potential, which is where it's attracted to. What's going on? The following possibilities are the ones that occur to me. (1) My intuition is just wrong. (2) The result is qualitatively different if there's a classically forbidden region separating the two sides. (3) The result only holds for [itex]E\approx 0[/itex], and for smaller energies it does what I'd have intuitively expected. (4) The result only holds because I chose [itex]V_L/V_R=4[/itex] to be a small integer, and I've been considering simple solutions where the quantum numbers are small integers.
I'll guess (3). Do we know the ground state energy?
I'm afraid the answer is (1).
Consider a classical elliptical orbit. The orbiting body spends less time near the body orbited and more time farther away (apogee dwell). The deeper the potential, the faster it's moving and the less time it spends there.
But in the ground state of the harmonic oscillator, the wave function is peaked at the deepest part of the well, which means it's most likely to be found there. At higher energies the wave function is peaked at shallower parts of the potential, suggesting the answer is energy dependent. So naively in the OP case I'd expect the ground state to also be peaked at the deepest part of the well. No?
The ground state is as close to non-moving as you can get: it's like having the pendulum at rest. Gaining intuition on how things move by thinking about states at rest is probably not going to work well.
Classically, I agree with V50, and the system does have the expected behavior in the classical limit. But quantum-mechanically, don't asymmetric diatomic molecules have dipole moments that arise from the tendency of the electron to be more localized in the atom that it's more attracted to?
I'd think the classical limit of the harmonic oscillator would be an incoherent superposition of high-n states in some range of energies. Check out the third figure (the orange one) in this WP article: http://en.wikipedia.org/wiki/Quantum_harmonic_oscillator The high-n states have the classical behavior, but the low-n ones don't.
But are options (1) and (3) contradictory? I do think your intuition is just wrong for the energy you specified - in that sense I agree with V50 (1). But perhaps it is right for the ground state (3).
These guys give solutions for a related situation: http://pubs.acs.org/doi/abs/10.1021/ed085p591. The ground state is peaked over the deeper well.
I tried http://fermi.la.asu.edu/Schroedinger/html/node2.html#applet with
V(x) = -4*pulse(x+1,1)-pulse(x-1,1)
xmin=-2.0
xmax-2.0
Vscale=10.
I think each of the two intuitions correspond to whether the state is "bound" or "free", roughly speaking. In the former case, the intuition that it should spend its time in the deeper well applies. in the latter case, the arguments from classical kinetic energy apply.
Cool applet!
Yes, I think I agree with #7. Both the ground state and the high-energy states behave qualitatively as we'd expect classically.
I was able to get a reasonable mockup of my original problem (with infinite walls) with this potential:
a=0.2
b=5
max(a*x^4-b,-4*pulse(x+1,1)-pulse(x-1,1))
With "Nodes" set to n=0, I get the ground state, which is peaked in the lower well. n=1 is roughly equal on the two sides. n=2 is strongly peaked on the right. n=3 and higher is about the same on both sides. The n=2 case is the one where both sides are classically allowed, and the energy is comparable to Vo.
I played a little with the applet to try and build intuition.
Starting from atyy's conditions, I made the left well deeper and deeper. As I did this, the wavefunction moved more and more to the left. Classically, a particle that isn't moving sits at the bottom of the potential well.
I then went back to the original potential, and started increasing n. For n large and/or even, the situation looks like it does classically - the particle spends most of its time in the shallower potential. For n small and odd (i.e. 1 for this potential, 1 or 3 for a deeper potential where the 4 becomes a 20) it starts to look like a finite potential well - the wave function is oscilliatory in the deep well and exponential in the shallow well.
While the rough intuition for the 2 extremes (ground state and highly excited states) seems ok, it does indeed seem to fail for small, even n like the first excited state. I guess it's too much to ask for intuition to cover everything? After all, it already fails for explaining why the ground state has non-zero expected kinetic energy?
(It's intuitive if we know it's a wave equation, but I don't think that's what was being asked.)
The first excited state is going to be funny, since it's behavior depends on whether the first node is on the deep side of the potential, the shallow side of the potential, or near the border.
FAQ: What is the behavior of an electron in an asymmetric potential well?
1. What is an asymmetric potential well?
An asymmetric potential well is a type of potential energy function that has an uneven shape, with one side being higher than the other. This creates an energy barrier that particles must overcome in order to move from one side of the well to the other.
2. What is the significance of an asymmetric potential well in physics?
Asymmetric potential wells are commonly used in physics to model various systems, such as quantum mechanical systems and electrical circuits. They can also help explain phenomena like tunneling and energy levels in atoms.
3. How is an asymmetric potential well different from a symmetric potential well?
In a symmetric potential well, the shape of the potential energy function is the same on both sides, creating a balanced energy state. However, in an asymmetric potential well, the shape is uneven, resulting in an energy imbalance and the possibility of particles being trapped on one side.
4. What is the role of an asymmetric potential well in quantum mechanics?
In quantum mechanics, asymmetric potential wells are used to describe the behavior of particles, such as electrons, in a potential energy field. They help explain the concept of quantum tunneling, where particles can pass through energy barriers even if they do not have enough energy to overcome them.
5. How are asymmetric potential wells created in experimental settings?
Asymmetric potential wells can be created in experimental settings using techniques such as applying an external electric field or using laser beams to manipulate the energy levels of atoms. They can also occur naturally in certain physical systems, such as in semiconductors or in the Earth's atmosphere.
