Deriving the atan2 Function from Tangent Half-Angle Formulas
The discussion focuses on deriving the atan2 function using tangent half-angle formulas. The formula presented is atan2(y, x) = 2arctan(y / (√(x² + y²) + x)). By substituting y = r sin(θ) and x = r cos(θ), the expression simplifies to sin(θ) / (1 + cos(θ)). This leads to the conclusion that this expression equals tan(θ/2), confirming the derivation of the atan2 function. The derivation process is clarified and validated through these mathematical transformations.
mnb96
Hello, it is mentioned http://en.wikipedia.org/wiki/Atan2#Definition" that using the tangent half-angle formulas it is possible to express the function atan2 as:
\mathrm{atan2}(y,x)=2\mathrm{arctan}\frac{y}{\sqrt{x^2+y^2}+x}
How can I derive this result?
Mathematics news on Phys.org
Put y = rsinθ, x = rcosθ, then y/(√(x2 + y2) + x) = sinθ/(1 + cosθ),
which you should be able to prove is tan(θ/2) :wink:
Thanks!
Now it´s clear where that formula came from.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
