Atmosphere of earth - why it isnt static?
The Earth's atmosphere is not static due to its connection with the planet's rotation and the effects of friction and drag. As the Earth spins, the atmosphere moves with it, preventing extreme conditions that would occur if the air remained stationary. Factors such as temperature, density, and pressure differentials contribute to the dynamic nature of the atmosphere, influencing weather patterns and heat distribution. This interaction between the Earth's surface and the atmosphere is essential for maintaining a stable environment. Overall, the atmosphere's movement is a result of complex physical interactions rather than remaining fixed in place.
player1_1_1
here is Earth and here is atmosphere. Why this atmosphere is going around with Earth when it is going around, not stay in one place static? i mean not this motion around sun but this motion which is making day and night, the air and everything else is going around with about 1000m/s speed (on equator), how it can be explained?
Friction, drag. If the air stayed in place and the Earth was spinning through it at 1000m/s (at the equator), things would be pretty "interesting" to say the least.
haha, would be nice wind;]
so it is connected with this "friction" and if this didnt exist on Earth all things would stay in one place while Earth would spin around?
Air is a fluid, and fluids are subject to friction and drag when they move at different speeds than solids with which they are in contact. There are lots of other things that cause the air to be dynamic, too, like differentials in temperature, density, and pressure. That causes our weather, and transports heat and water around our planet.
