Why does atmospheric pressure not keep liquids inside upside down cups?
Atmospheric pressure can keep liquids inside narrow containers, like straws, but this effect diminishes in wider openings, such as upside down cups. For liquids to remain in an upside down cup, the pressure must be evenly distributed across the surface, which is disrupted by even slight variations. When the cup's opening is wide, these variations can lead to air bubbles forming, breaking the seal and allowing the liquid to escape. In contrast, narrow straws limit the potential for such disturbances, maintaining the liquid's position. The discussion highlights the importance of the opening size in determining whether atmospheric pressure can effectively hold liquid in place.
electronicsguy
If I hold the top end of a straw filled with water, the water stays in the straw which is due to the atmospheric pressure. How come this effect is not seen in upside down cups? Should the atmospheric pressure keep the liquid inside it within the cup since the other end is closed? Also, the radius of the cup is greater which means greater upward force.
Welcome to PF;
You do see this effect in upside down cups - provided the mouth of the cup is below water level.
The key here is the width of the opening.
For the pressure difference to hold the water in the container, it needs to be exerted evenly over the whole surface.
A small variation, even for a moment, will make one side heavier, allowing a bubble of air to form and break the seal. You can see it if you use a glass jar - watch the opening as you lift it clear of the water.
Over a small surface, though, the variations do not usually build up so much.
You can break the symmetry by tilting the straw (if i's a wide one).
[If the straw is very narrow, then capillary effects can become important too.]
Your narrow straw is just restricting the number of things that can possibly go wrong ;)
The classic demonstration of the effect is in a vortex bottle -
http://www.instructables.com/id/How-to-Make-a-Vortex-in-a-Bottle/
... the connecting hole has to be small (how small? experiment!) to make it work.
If you just up-ended the bottles quickly, no vortex forms, and water does not flow from one bottle to the next.
Ok so the uneven force of the atmospheric pressure due to a wide opening does not hold the liquid in tact. How does this have anything to do with the vortex bottle?
Try the bottle and see - experiment with different sized holes (without swirling the water).
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
